Thread: mounting amp
05-24-2006, 07:35 AM #1Member
- Jun 2005
- 51
mounting amp
i am looking at mounting my amp, and i want to mount it on the gunnel side of the ski locker. I am considering pulling down the carpet and glueing a piece of mdf directly to the fiberglass then putting the carpet back over it. has anyone tryed this? what adhesive?
05-24-2006, 08:14 AM #2Senior Member
- Dec 2004
- Cinci-Dayton
- 1,014
Replying to Topic 'mounting amp'
I’m not sure where the gunnel or the ski locker is, is this where the amp is usually mounted – below the glove box on the fwd wall? Mine is mounted there through the carpet with 1.2” screws (I think). Your idea is better if you find the right glue. I’d guess a glue gun type of glue but be sure it is what you want and where you want it.
SD2Naked red and white 2005 Moomba LSV
05-24-2006, 09:22 AM #3Senior Member
- Mar 2004
- Wylie, Tx.
- 212
I, like smoke, had mine under the glove box mounted vertically on a board the I had covered in the same carpet. Two reasons for where I put mine was that it was protected for the most part from water, except when the glove box had water in it( long story) and it was easy to access the stereo and batteries. Only issue that I had was heating. It never overheated, but you would get quite the suprise reaching in for a towel and touching the cooling fins.
MedicMedic151
06 Mobius XLV
05-24-2006, 05:14 PM #4Senior Member
- Jul 2003
- 340
Are you talking about the center ski locker in the floor of the front of the boat? If so I would worry about this a little, especially if you have the ballast system. I can see a hose popping of the bag and causing some water damage to your amp. I could also see some long term issues with this even if you don't have the ballast system. It seems like that area always has a little bit of water in the bottom of it. Over time I could see the moisture in that compartment giving your amp some problems.
Amp Mounting Location
By cab13367 in forum General ChatReplies: 8Last Post: 04-22-2008, 10:58 AM -
Tower Mounting Base
By KidFlippy in forum Service & RepairReplies: 0Last Post: 10-09-2007, 04:28 PM -
Orange Flag -mounting tip for-Wakeboarding/Skiing/Swimming
By Bulldgz in forum General ChatReplies: 10Last Post: 08-19-2007, 10:50 AM -
Mounting questions
By barefooter in forum Service & RepairReplies: 7Last Post: 06-28-2003, 11:25 PM
