Results 1 to 10 of 23
03-17-2015, 04:36 PM #1
What kind of jack do you use for your trailer?
just curious as to what everyone uses for changing trailer tires on the road. I have used the one from my Suburban for the most part but it really doesn't work very good. I would like to find something better that I can throw in back of the Suburban when heading out.
Scott
2021 Craz
1997 Sea Ray 190
03-17-2015, 04:52 PM #2
Well, when I do a bigger trip, I just throw the aluminum floor jack into the trunk of our truck.
www.TraysonsToybox.com
03-17-2015, 04:58 PM #3
I have a bottle jack I carry around in the truck. Also carry some blocks of wood in case I need to prop it up a bit. I've used it quite a bit for the camper and boat trailers already in the last few years.
2015 "NOT A MOOMBA"
Why Not? Play Hard! Get wet
03-17-2015, 05:42 PM #4
I've used the bottle jack out of the truck as I do not have a desire to haul around the 70lbs floor jack I use around the house. Bottle jack is a pain but it works. And like Viking I have taken a few 2x6's and made a ramp since I have a tandem trailer I can use the wood rather than a jack all together.
2017 Centurion Ri237
2013 Supra SA450 - Sold
2006 Mobius LSV - Sold
2004 Stingray 190LS - Sold
03-17-2015, 05:48 PM #5
I use the same jack as Trayson mentioned, its pretty light, 25ish pounds I think. I only have taken it on long trips, long as in out of state.
I took it not only for the boat but because I don't like factory truck jacks and in case i got a flat on it.
I think Bottle jacks are fine, with some wood blocks to add stability.Malo <--- Means--Evil or Mean One. This explains a lot.
[COLOR="#696969"]
03-17-2015, 05:54 PM #6
Perfect size with a case for travel.
PWI as usual...
03-17-2015, 07:52 PM #7Senior Member
- Nov 2014
- Columbus, Ohio
- 388
I use one of these....
https://www.etrailer.com/Merchant2/g...20_14_1000.jpg
or in the past had one of these...
http://ecx.images-amazon.com/images/...8L._SX522_.jpg
Much quicker than a standard jack and I don't get dirty or as sweaty crawling around on the ground getting it setup.
Plus it's light and compact that I just attached it to my spare tire so it's always with the trailer. I just keep my lug wrench under my trucks backseat and I'm good to go.Boatless for now
03-17-2015, 10:59 PM #8
I just lift it up by hand and spin the nuts off. No wrench or jack needed. If we forget the spare I just run along side and hold her up. This is usually only good for a hundred miles or so though. Eat right and take care of yourself.
03-17-2015, 11:13 PM #9
Kane, We talking about the same thing?
PWI as usual...
03-18-2015, 10:01 AM #10
I always carry my floor jack on long trips. It has come in handy a couple of times and makes the job so much easier.
