Results 21 to 30 of 71
03-18-2015, 04:11 PM #21Malo <--- Means--Evil or Mean One. This explains a lot.
[COLOR="#696969"]
03-18-2015, 05:25 PM #22
Polyester fiberfill (pillow stuffing) is effective if you have an under-sized enclosure....within limits. It can only address the displacement to a degree but 10% is within that range. It converts acoustic energy to low level thermal energy which gets dissipated thereby simulating a larger enclosure.
You know when you have gone too far with too much fill material when the bass gets a little 'flat' or 'dead' sounding, similar to having too large of an enclosure. An enclosure that is too small typically sounds peaky in favor of the midbass. So too small is very 'live' but also becomes a little singular in its tone. These descriptions are probably a better guideline then just trying to judge the difference in low bass extension.
03-18-2015, 05:35 PM #23
Thanks for the info guys.
The interior volume of the box has 0.60 cuft for each sub.
Each of the subs are spec'd for 0.75 cuft. sealed. so it sounds like the fiberfill should help.
I'm thinking somewhere in the range of 1 to 2 pounds total filling.2008 Moomba Mobius XLV. Monster Cargo Bimini, WS Rev 410's, Polk Cabins, 3 Infinity Subs, PPI amps, WS420, Exile BT, upgraded ballast pumps, up to 3,500+ pounds of ballast, Blue LED's...
www.TraysonsToybox.com
03-18-2015, 05:45 PM #24
I agree with you, in the Vette factory was a 6inch and I have 8s now. With no batting material it had a weird matalic echo almost. With the batting its a much deeper natural sounding bass.
For the 15 I didn't add to much, just enough to cover the insides of the box. I felt it made it sound warmer as well.Malo <--- Means--Evil or Mean One. This explains a lot.
[COLOR="#696969"]
03-18-2015, 06:22 PM #25
Wouldn't have a clue as to the weight. So you are way ahead of me. But I would use the loose material rather than the batting for this particular application since you are not just lining the walls. Start by tearing it apart and loosely filling the entire enclosure. I don't have a cover story for you when your wife asks why the couch pillows suddenly seam flat.
03-18-2015, 06:24 PM #26
03-18-2015, 06:25 PM #27
03-18-2015, 06:37 PM #28
You guys are awesome and amusing.
03-18-2015, 07:16 PM #29
03-18-2015, 08:08 PM #30
