Results 1 to 2 of 2
Thread: 2015 Mojo Trailer Length
03-08-2015, 06:25 PM #1
Any insight regarding the following:
1) Length of the 2015 Mojo trailer with the swing away tongue including trim tab?
2) Can the rear swim platform be removed?
3) How easily can the swim platform be removed?
I'm trying to determine if the boat will fit into our lake-house garage. My boat doesn't arrive till mid April. I can check with the dealer on Tuesday, however I was curious if a forum member had an insight.
Thanks.Last edited by pdhj1990; 03-08-2015 at 06:31 PM.
Paul
2015 Mojo, Surf Edition
Lake Texoma
03-08-2015, 08:30 PM #2
I don't know the exact length on the trailer of the 23ft.
I'd assume its got to be pretty close to the 22.5
22.5 need 23ft with the wake plate. I am going to say you need 23.5 to 24ft with the wake plate.
Yes the swim deck can be removed, its 2 pins, and takes two people to do it safely. You remove both pins, tilt the deck up towards the boat and then lift off.Malo <--- Means--Evil or Mean One. This explains a lot.
[COLOR="#696969"]
