Results 1 to 5 of 5
    Feb 2006
    Birmingham
    Default Prop Shaft Alignment help....
    I attempted to check the alignment on my prop shaft on the V-drive and just ended up really confused. I got out the offset gauges and tried to check the gap in the flange. I could not get any of the gauges between the flange. What is the proper way to check the engine alignment in a V-drive. There did not appear to be any space at all any where on the flange. Could someone send me the proper instructions or just point me in the right direction? Any help would be appreciated.
    15 Mondo Surf Edition
    02 LSV - Traded In
    Default Replying to Topic 'Prop Shaft Alignment help....'
    You did loosen the 4 bolts?
    99 Outback LS. Sold
    Guest
    I really do not want to look like an idiot, but no I did not. I was not sure if there was some type of rubber flange in the center similar to a harmonic balancer. Are there any instructions available for download or has anyone been sent instructions? I just took a quick glance at it and decided to post and ask you guys what to do before I really end up screwing something up. Thanks.
    send me your email and i'll send you the procedure for my boat, its a dd , i imagine the procedure is similaron a vd just think how you want the engine to tilt to get proper alignment
    99 Outback LS. Sold
    Feb 2006
    Birmingham
    02 LSV - Traded In
Similar Threads
  1. Prop shaft mount
    By tkderose in forum General Chat
    Last Post: 04-25-2008, 10:29 AM
  2. Prop and shaft rotate while in neutral
    By Derteeberd in forum Service & Repair
    Last Post: 08-03-2006, 05:11 PM
  3. Bent prop, strut and shaft
    By Rugburn in forum Service & Repair
    Last Post: 07-29-2006, 11:41 AM
  4. Prop/Shaft Damage?
    By Nboard10 in forum General Chat
    Last Post: 04-03-2006, 03:12 PM
  5. Noise from prop/shaft
    By Livindadream in forum Service & Repair
    Last Post: 09-09-2005, 04:37 PM
