Results 1 to 8 of 8
02-19-2015, 01:29 AM #1
Plumbing the 1180 Gravity Games center basement Bag in 2008 XLV
So, I have the 1180 gravity games bag. And I'm also upgrading my ballast system.
The gravity bag has 3 ports. One end has a port on the bottom rear and another port on the top rear.
The other end has a port that's at the front, and could be oriented to be at either the bottom or top.
So, my inclination would be to have the bag setup as follows:
- Lower stern port = drain
- Upper Stern Port = Fill
- Upper bow port = Vent
Another option might be as follows, but it would needlessly lengthen the fill hose length and add head pressure:
- Upper or lower bow port = fill
- upper stern port = vent
Any thoughts on this?2008 Moomba Mobius XLV. Monster Cargo Bimini, WS Rev 410's, Polk Cabins, 3 Infinity Subs, PPI amps, WS420, Exile BT, upgraded ballast pumps, up to 3,500+ pounds of ballast, Blue LED's...
www.TraysonsToybox.com
02-19-2015, 02:12 AM #2
I would think the vent line at the highest point (upper bow port) will offer the best results,
2018 Max with a little extra weight here and there
02-19-2015, 04:28 AM #3
I made my plumbing with a reversible pump and used only the lower stern port. I used the upper port and "
crossed" the vent lines, the starboard side ventilation thru the port side hull and vice versa. This way the water will stay in the ballast when the boat is tilted
02-19-2015, 05:56 AM #4
Agree with Boonejeepin. Upper bow port vent.
Joe
2014 LSV
2010 Outback V - Sold
1993 Echelon
02-19-2015, 01:27 PM #5
Thanks guys.
02-19-2015, 10:44 PM #6
02-20-2015, 02:02 AM #7
CHECK! the venting will most certainly be from the bow. Just wanted to bounce it off ya'all in case there was something I hadn't thought of.
02-20-2015, 02:09 AM #8
ya the bow. definitely the bow.
