Results 1 to 10 of 20
02-12-2015, 03:12 PM #1
Is my accessory switch likely controlling anything??
So, I was looking at my switches. On the far right, I have an accessory that will power something on in the up position and something else on in the down position.
I didn't get out my test light and I didn't start chasing wires. But I figured I'd ask here in case anyone knows. What if anything is likely to be wired up to this? I have a separate switch for "stereo" and my 12v outlets are wired hot. So is it likely that I have a free switch that I could use for adding stuff to my boat? (Like LED accent lighting?)
www.TraysonsToybox.com
02-12-2015, 04:00 PM #2Junior Member
- Aug 2014
- Cincinnati
- 23
Sounds just like the accessory switch in my outback, I assumed it was for ballast pumps and that is what I used it for, up is fill and down is empty.
02-12-2015, 04:05 PM #3
I already have a bank of 3 switches for my Gravity III ballast system that came from the factory. It's below the throttle and you can kind of make it out in this pic.
02-12-2015, 04:28 PM #4
My bet is that it's just powered up so the lights on the front work but the switch doesn't control anything. I used it for the heater (up = high, down = low.)
02-12-2015, 04:45 PM #5Senior Member
- May 2013
- 253
The only double throw switch I think I have is for my heater
02-12-2015, 06:21 PM #6
It's not your courtesy lights is it? The tiny ones that barely light up the floor and you can't even see in the daytime.
02-12-2015, 08:25 PM #7
It is for the heater if you had one. All the switches are powered from the factory even if they are not used.
Joe
2014 LSV
2010 Outback V - Sold
1993 Echelon
02-12-2015, 11:12 PM #8
There is a extra switch there,I hooked my LED accent lighting to it.
2018 ?????
2013 LSV Exiled (Sold)
2006 LSV (Sold)
Jim
02-12-2015, 11:29 PM #9
02-16-2015, 05:01 PM #10
