Results 1 to 10 of 16
    Jan 2006
    Candler, North Carolina
    Default Impeller Removal
    I am going to replace the impeller on my boat that I recently boat used. I need to know how to go about this, do you use a pair of needle nose pliers and grab around one of the rubber fins on the impeller or is there another way to go about this. Thanks alot for the help.
    Jan 2006
    Default Replying to Topic 'Impeller Removal'
    I forgot to say my boat is an 04' Outback Direct Drive.
    Mar 2003
    Springfield Missouri
    A search of the posts would give you this one:
    http://www.moomba.com/bb/viewtopic.php?t=2034
    1998 Mobius
    310 HP PCM
    SOLD
    Feb 2006
    Birmingham
    I take needle nose pliers and stick one side in the brass end of the impeller and the other in between two fins and then just pull and wiggle it like hell!
    15 Mondo Surf Edition
    02 LSV - Traded In
    Apr 2006
    You can also use two screwdrivers. Stick them in between the blades on opposite sides of the impeller and gently pry both sides at the same time. Mine came right out using this method and it shouldn't tear the blades. You can use it as an emergency spare.
    Jman
    Aug 2004
    Lake Hickory, North Carolina
    Also, be careful not to apply too much torque to those 4 lil' screws. You can strip the threads out of the holes or twist the head of the machine screw off.
    B
    Sep 2002
    Pennsylvania
    Ed’s suggestion works like a charm. I have found that Aero Kroil from http://kanolabs.com/ works better then WD-40.
    Good luck, E
    Oct 2004
    SE MI
    What I found works best is two paint can openers from your hardware store. They do not damage the impeller. I pull mine every winter and put a little dish soap in a ziplock bag. Mine is good for about 3 seasons this way with about 50 hours a season.
    Jun 2005
    WHere would the impeller housing be on my 99 outback LS?
    THanks,
    Joey
    Mar 2003
    On the lower front of the engine right off the drive shaft. About 4 inches behind the ski pylon as the pylon gets in the way a bit when getting the screws out. There's an "O" ring on the front cover and I can't remember if the replacement impeller comes with a new "O" ring.
    1998 Mobius
    310 HP PCM
    SOLD
  1. Raw Water Pump Removal
    By dtlaine in forum Service & Repair
    Last Post: 07-10-2008, 04:11 PM
  2. Rad-A-Cage Tower Removal
    By Dano in forum Service & Repair
    Last Post: 06-19-2007, 08:11 AM
  3. Prop Removal
    By cham783 in forum Service & Repair
    Last Post: 08-17-2005, 01:20 PM
  4. Floor panel removal??
    By MEDIC151 in forum General Chat
    Last Post: 03-26-2004, 01:42 PM
  5. Stain removal from vinyl
    By moombaschleg in forum Boat Owners
    Last Post: 07-10-2003, 12:16 AM
