View Poll Results: Should I criss cross my rear bag drain hoses?
- Voters
- 6. You may not vote on this poll
Yes: have the port drain on the starboard side
3 50.00% -
No: have the bags drain on their respective sides of the boat
3 50.00%
Results 11 to 20 of 24
02-07-2015, 08:14 PM #11
How about you just install Impeller style pumps, then they fill drain under the boat, this helps your OCD, and then Cross your Vents and you will never be the wiser?
[COLOR="#696969"]
02-09-2015, 03:52 PM #12
My vent/drain thru hulls sit several inches lower than the tops of my bags so leaning = draining... At least until the bags are the same level as the thru hull is. You don't HAVE to criss cross both, just the vent, but may as well do them both to keep your wits about you.
My $.03
02-09-2015, 04:29 PM #13
I am going to use the existing "drain" thru hull for the vent. That is located between the crossmember that's between the seat backs and the front of the locker. So it's certainly forward relative to the locker itself.
That said, I am planning on placing the drains through new thru-hulls. I could mount these way further up on the hull. Heck, I could easily go just behind where the speakers are.
So are you talking about mounting the DRAIN thru hull forward? or the Vent? or both? Please expand on what you're trying to suggest for me.
Life would be easier if I'd gone impeller. But I still think they'd be slower. I've set my course, so I'm going to run with it....2008 Moomba Mobius XLV. Monster Cargo Bimini, WS Rev 410's, Polk Cabins, 3 Infinity Subs, PPI amps, WS420, Exile BT, upgraded ballast pumps, up to 3,500+ pounds of ballast, Blue LED's...
www.TraysonsToybox.com
02-09-2015, 04:37 PM #142008 Moomba Mobius XLV. Monster Cargo Bimini, WS Rev 410's, Polk Cabins, 3 Infinity Subs, PPI amps, WS420, Exile BT, upgraded ballast pumps, up to 3,500+ pounds of ballast, Blue LED's...
02-09-2015, 04:42 PM #15
02-09-2015, 06:11 PM #16
Both. My neighbor's old Malibu had all the drains and vents near the transom. When the boat was surfing, and the bow was high, the front section of bags would rise above the thru hulls, and water would drain out. By cross venting/draining and forward thru hulls, no part of the bag will ever be higher than the thru hulls.
Joe
2014 LSV
2010 Outback V - Sold
1993 Echelon
02-09-2015, 06:17 PM #172008 Moomba Mobius XLV. Monster Cargo Bimini, WS Rev 410's, Polk Cabins, 3 Infinity Subs, PPI amps, WS420, Exile BT, upgraded ballast pumps, up to 3,500+ pounds of ballast, Blue LED's...
02-09-2015, 06:18 PM #18
It's a little off, like me.
I'm contemplating going with pirate ship mods and ditching the ballast bags in favor of ammunition storage to feed the built-in 50-cals.
I echo Joe's comments on the rear ports. My originals vented and drained out the back, whether I wanted them to or not.So when is this "old enough to know better" supposed to kick in?
02-09-2015, 09:24 PM #19Senior Member
- Apr 2009
- 233
Definitely cross them, and definitely do both the vent and the drain. In your case, since you're sharing that line, you can combine them and run one hose across the boat for each side.
If you had gone with reversible pumps you could use our double top secret passive drain blocker on the vent line, but since you need to be able to drain through that hose as well that's not really an option.
02-10-2015, 02:24 AM #20
Seriously this is a no brainer......same side and after you fill a wine cork will prevent any leakage. Yes if it's a new instal or you want to buy lots of hose go contra lateral side but otherwise just cork it.
09 21v LAUNCH
99 Outback LS. Sold
Doug
