Results 1 to 10 of 10
    May 2006
    Default 2001 Mobius LS weight with trailer weight?
    Hello!
    I own a 2001 Mobius LS. Currently I tow with a Ford F150. No problem towing. My wife and I are planning to buy a mini-van in the near future. The mini vans were looking at have a tow capacity of 3500 lbs. I know the 2001 Mobius LS weighs in at 2650 lbs. Does anyone know the weight of the trailer or the combined weight? Has anyone towed one of these with a mini-van?
    I welcome your assistance and comments.
    Thanks in advance!
    Mar 2003
    s.e. washington state
    Default Replying to Topic '2001 Mobius LS weight with trailer weight
    I have a 1998 Mobius at a combined weight of 3,200 pounds plus add the accessories and fuel and it would be around 3,500 pounds. The single axle trailer is rated for 3,450 pounds. I tried my 98 Chrysler mini-van with the 3.8L engine and it is doable on well maintained ramps. The front tires will smoke and you'll get an audience. I just use my Blazer and save the hassle. If you have rock or sand on the ramp, forget it. On the roads and highways, I have no problem towing the boat. I would only recommend the all wheel drive mini-van and I would try it out to see if you have any problems.
    1998 Mobius
    310 HP PCM
    Aug 2004
    Lake Hickory, North Carolina
    Recommend a vehicle with tow rating of at least 5000#. Boat, trailer, gear, people, and a cooler or two full of beer adds up quick. The 3500# vehicle will have no 'reserve' (and will prolly be exceeded in capacity). It'll be hard on it. But that's not to say you can't get by with one in a pinch. On a regular basis? I'd be concerned w/ safety.
    I upgraded my '99 Ranger to an '03 Sport Trac w/ trans cooler, limited slip diff, and auto trans (tow rating of 5500#). Bought it new as I was positioning myself to get me Outback. No worries (yet?).
    Hope this helps
    B
    Aug 2002
    Bismarck, NorthDakota
    I gotta say I hate the thought of a minivan pulling a Mobius,
    Just the thought makes me ill!!
    Bruce Fuerstenberg
    Aug 2002
    On the serious side when I bought my first Mobius LS I pulled with a S-10 blazer (V6)
    It pulled it but it was a lot of weight and there was noticable wear and tear on the blazer mainly the brakes, that is a lot of boat pushing. It was enough to give me the excuse to get a full size pickup!
    Bruce Fuerstenberg
    Mar 2003
    Yea, my Blazer would be marginal for distances because it lacks the tranny cooler but I usually take my motorhome. The minivan actually pulls the boat better than the Blazer mainly because of the wider wheelbase but the front wheel drive is a killer on inclines. If one is looking for a pulling rig you need to look around the parking ramp and see what people are driving. There's a reason why those vehicles are used and others are not.
    1998 Mobius
    310 HP PCM
    Dec 2005
    Ontario
    I use a 2000 Jeep Grand Cherokee with the 8 cylinder engine.
    Funny when I look around the ramp I see lots of pickups, tahoes not too many Jeeps. The Jeep has way more than enough towing capacity...and is a great alternative to minivans..
    Just a suggestion!!
    2005 Moomba Outback
    Sep 2002
    Pennsylvania
    I also use a Grand Cherokee 2004 V8 HO. It does a fine job towing my LS but I did add a Tibren kit to help out it makes a huge difference (http://www.timbren.com/).
    If you are dead set on the mini van I would consider beefing up the suspension a bit.
    E
    Sep 2002
    Pennsylvania
    Ok lets try that again,, http://www.timbren.com/
    Dec 2005
    Ontario
    ya i dont find any issues but Iknow your boat is heavier than mine.
    Im looking into that suggestion all the same because from time to time i do pull heavier loads...
    2005 Moomba Outback
  1. How Much Ballast Weight?
    By chadgreg in forum General Chat
    Last Post: 02-08-2008, 01:48 PM
  2. how much weight do I need?
    By INlakeOutback in forum Wakeboarding | Wakeskating
    Last Post: 06-15-2007, 08:07 AM
  3. How much weight?
    By superman in forum General Chat
    Last Post: 05-24-2007, 09:50 AM
  4. Boat and trailer weight URGENT
    By matman in forum General Chat
    Last Post: 06-30-2006, 08:34 AM
  5. Trailer Tongue Weight
    By Lake Bound in forum General Chat
    Last Post: 03-25-2004, 11:20 PM
