Results 41 to 45 of 45
09-22-2015, 01:22 PM #41Junior Member
- Sep 2015
- 8
I guess I can't see where you are tying into the engine unless you disconnected the inlet hose from the bottom of the boat.? I guess I will just tie into the impeller housing unless I hear otherwise from you guys. I am waiting for my oil and filter to be delivered and then I will post pictures of my set up. Then I will inspect the impeller as I ordered one of those too.
09-22-2015, 01:23 PM #42Junior Member
- Sep 2015
- 8
Thanks Jordy
09-24-2015, 02:29 PM #43
2007, thats right. Viking was referring to hooking up your garden hose fitting to the suction side of the impeller housing. Viking was essentially doing the same thing but because he had a sea strainer installed he was hooking up to the sea strainer housing (which feeds the suction side of the impeller housing). If you ever need help just drop a line. I have the same boat
09-29-2015, 11:00 PM #44Junior Member
- Sep 2015
- 8
Successful first oil change. Learned a few things too. 1. It takes a while to drain the oil without an pump 2.Removing the oil filter is a messy job. 3. When you clean up put in the cooler plug so the oil and degreaser doesn't run in the cooler. Next I will have to learn how to change the transmission fluid.image.jpgimage.jpg
09-30-2015, 08:01 AM #45
Make sure and run the engine to get it up to temp before draining oil. That should help. Use the same extractor for the tranny fluid as you do the engine oil. Pull the dipstick plug and suck all the fluid out. Replace. It's that easy. For the engine filter use a large zip lock bag to cover up filter as you remove. It'll catch most if not all the oil spill and no mess in the bilge area.
2015 "NOT A MOOMBA"
Why Not? Play Hard! Get wet
