Results 1 to 10 of 13
Thread: FAE install
05-14-2006, 01:14 PM #1Senior Member
- Dec 2004
- Cinci-Dayton
- 1,014
FAE install
I found the camera and had to upload the Easter pictures for the in-laws so here is the FAE pix – I think. I did not do the install to spec as the 2” spacer is NOT between the platform bracket and the FAE support bar. I felt it was a more solid attachment with the bar against the bracket and with the spacer on top, the bar hit the vertical (hypotenuse) bracket support. If I had shorter bolts, I would not have used the spacer at all.
I did buy Al shims for the platform to clear the bolt heads.
http://faeinstall.shutterfly.com/act...b0510&pg=0Naked red and white 2005 Moomba LSV
05-14-2006, 01:22 PM #2Senior Member
- Dec 2004
- Cinci-Dayton
- 1,014
Replying to Topic 'FAE install'
yes, I should have drilled a hole for the bolt head and centered the shim - I was in a hurry!
SD2Naked red and white 2005 Moomba LSV
05-15-2006, 06:05 PM #3Senior Member
- Oct 2005
- 199
Looks nice SD. Thanks for the info guys. How's the noise level inside the boat, especially for anyone seating in the back?
05-16-2006, 01:42 AM #4Junior Member
- Feb 2006
- Scottsdale, AZ
- 28
SD,
Good pics. I did a few things differently. I cut the support bar and drilled new holes so that it would fit between the platform supports. I also bent the all-thread rods so that they came straight up from the FAE instead of at that funky angle. Sounds like Larry at FAE is changing the length of the support bar now so hopefully no one else on here will have to make modifications.
Overall, this is a great product - very well built and it does what it was advertised to do. The istallation was pretty frustrating, but I'm very happy with the way it turned out.
Thanks again for the pics SD!'06 Mobius LSV.
05-16-2006, 07:35 AM #5Senior Member
- Dec 2004
- Cinci-Dayton
- 1,014
Significantly less. worth the money just for that.
05-17-2006, 08:35 AM #6Member
- Oct 2003
- Michigan
- 50
I hate to sound stupid - but what is an FAE, what does it do, and why did you add it to your boat?
05-17-2006, 09:46 AM #7Senior Member
- Oct 2005
- 199
Cool site: boatpipes.com.
05-17-2006, 10:00 AM #8Senior Member
- Mar 2005
- t-town
- 718
Fresh Air Exhaust.
It reduces the noise and also reduces the boat carbon monoxide output or at least put the monoxide directly under the water surface.
A lot of people who wakesurf are using this new exhaust to lessen the chances of being injured by these gases.
db
05-17-2006, 02:19 PM #9
I am lucky enpough to live an hour from Larry and I had install on my Outback and on my XLV . I highly recommend FAE. It works great for surfing and the noise level is way low. Actually got to surf with Larry once. Dude is bad to the bone. He was free lining with a surf skate (no fins) un real. His Trick Bordz are an awesome wake surf board as well.
trickboardz.com check it out.
05-19-2006, 09:10 AM #10Senior Member
- Mar 2005
- t-town
- 718
sd2, question- can you still remove your platform?
Asking because I have to take mine off in order to put it in garage.
doug
Please help with second battery install
By cj11302000 in forum General ChatReplies: 5Last Post: 06-25-2008, 02:23 PM -
DIY shower install
By newty in forum General ChatReplies: 13Last Post: 05-01-2008, 08:53 AM -
Tower install
By local 11 spark in forum Service & RepairReplies: 5Last Post: 03-26-2008, 09:45 PM -
Flush Pro install...
By 04OUTBACK in forum Service & RepairReplies: 6Last Post: 12-28-2006, 02:36 PM -
Shower Install
By waterboy in forum Boat OwnersReplies: 4Last Post: 12-03-2003, 04:01 AM
