Results 1 to 10 of 28
Thread: impellar pumps
11-07-2014, 10:42 AM #1
impellar pumps
Are impeller pumps strong enough to fill/drain through 1180 in the ski locker to two 250 lb bags in the bow teed off and vented with a CV?
creating my black Friday shopping listA Day at the Lake...Priceless
11-07-2014, 12:19 PM #2
It will, but it will slow due to the head pressure.
11-07-2014, 12:27 PM #3
I'm so tempted, but not even gonna touch that one...
11-07-2014, 02:12 PM #4Senior Member
- Oct 2013
- Ft. Collins, CO
- 688
I respectfully disagree. The pump performance will only decrease about 1% due to the head pressure. The Johnson spec is 822 gph @ 0 psi and 810 gph @ 1.4 psi which is 3'3" http://www.pumpvendor.com/media/john...690_series.pdf User tests confirm that these pumps are not greatly affected by head pressure. Of course, aerator pump performance would be greatly reduced due to the head pressure.
1989 Sanger Skier DX - sold
11-07-2014, 03:07 PM #5
11-07-2014, 03:09 PM #6
11-07-2014, 05:55 PM #7Senior Member
- Aug 2011
- 2,522
Re: impellar pumps
That's close to my setup, center bag fills the IBS, the vent is connected to the IBS with a 1 way valve...
2002 Moomba Mobius LSV - Sold
2006 Moomba Mobius LSV - Sold
11-08-2014, 08:46 AM #8Hey, Its Moomba time
13 Mobius LSV-sold
08 Mobius LSV-sold
03 Mobius LSV-sold
11-08-2014, 09:44 AM #9
Plenty of time at the end if the dock to fill the cooler with beer...
11-09-2014, 02:09 PM #10
An Impeller pump will absolutely be effected. Im not talking about a 3ft lift from the sac to the pump, but talking about pushing through the bottom port of a sac with 1K+ water in it, forcing the over flow into another sac thats located a few feet away and on a higher plane. This is based on actual experience, not printed specs. As stated, yes, it will work, but it will slow greatly, once the belly sac is filled. So if a 3'3" 1" OD hose creates 1.4 PSI, what would a 141 gallon sac build?
