Results 1 to 10 of 26
Thread: Depth Gauge on a 2008 XLV
11-04-2014, 02:46 PM #1
I am curious if my depth gauge is a thru hull or an in hull transducer on my 2008 XLV.
I'm wondering because if it's a thru hull, I wonder if it happens to have a transducer that has a water temp signal built in. If so, then it would make sense that one could swap out the gauge and get one that reads both water temp and depth.
If the transducer doesn't have a temp output, then I wonder if I could tap into the output on the perfect pass paddlewheel that gives water temp. (Yes, I know that I can have PP tell me the water temp, but having it just "displayed" would be nicer than having to press Menu/UpArrow, menu, menu, menu, uparrow. It's pretty much a combination of keystrokes that only I remember so if I'm not driving I have to go up there and press through all the menus to get the info.
I think a display like this would be nicer on the depth gauge:
www.TraysonsToybox.com
11-04-2014, 03:21 PM #2
I am pretty sure the depth gauge is "in Hull" it is glued to the bottom of the boat, somewhere near the transmission I think. I like the faria gauge too. I had put gauge in my previous boat. I think that also has an air temp sensor as well, that was nice to know too.
I think that i have heard of tapping the PP temp sensor for this, but i am not sure. good luck.19 Mondo
08 LSV, forever loved
11-04-2014, 03:58 PM #3Member
- Jul 2014
- Eastern Ontario
- 72
My XLV did not have a depth gage. I installed a Lowrance 5 DSI chart plotter (and fishfinder) $350? CDN plus map chip $99?...hundreds of lakes). I glued the transducer to the left of the transmission looking aft, works fine. Cool thing about it is that it can store all of your tracks from your activities, I try to stay on my previous "Safe" tracks. My budget this year and next does not have any $ for replacement of rudder, prop, and shaft etc, I am pretty sure it saved me this repair once as I could "see" what was ahead and missed a rock shelf only 24" deep, buoy was 60' to the left of it where it is only 12" deep. Another guy with a Nautique lost his running gear on it two days later, he was new to the lake.
2007 Moomba Mobius XLV with G3 Ballast, 325HP Indmar, Carbureted
Extreme Noob
11-05-2014, 11:08 AM #4
The PP on my 2008 LSV displays the water temp all the time. Are you sure it's not just a setting in one of the menus.
11-05-2014, 12:19 PM #52008 Moomba Mobius XLV. Monster Cargo Bimini, WS Rev 410's, Polk Cabins, 3 Infinity Subs, PPI amps, WS420, Exile BT, upgraded ballast pumps, up to 3,500+ pounds of ballast, Blue LED's...
11-05-2014, 03:22 PM #6
I know on my 08 LSV the Paddle wheel has the Temp sensor. If you have a True GPS PP then it wont use the Paddle Wheel and this is why you won't have a temp.
[COLOR="#696969"]
11-05-2014, 03:28 PM #72008 Moomba Mobius XLV. Monster Cargo Bimini, WS Rev 410's, Polk Cabins, 3 Infinity Subs, PPI amps, WS420, Exile BT, upgraded ballast pumps, up to 3,500+ pounds of ballast, Blue LED's...
11-06-2014, 10:09 AM #8
Not any more. Here's pics of it off and then on.
PP ON.jpgMy Mom said I'm not allowed to get wet!
11-06-2014, 10:16 AM #9
Dug out my manual. It says Wakeboard Pro by Perfect Pass, DBW, Version 6.5NG, July 2007.
11-06-2014, 12:20 PM #10
Wow, that's exactly what I'd want. I just sent an email to PP to see if I can get them to walk me through changing the settings on mine to look like yours. If I can get mine working like yours, I'm going to be super stoked!!! (and this kind of "knowledge through sharing" is EXACTLY what these forums are all about)
