Results 1 to 10 of 11
Thread: Speaker Mount
    Sep 2014
    New Franklin, MO
    Default Speaker Mount
    Is this bracket for mounting a speaker?
    2015 Mobius LSV
    2014 Formula 350 CBR
    Jul 2010
    Vicksburg, MI
    According to my dealer, yes.
    Joe
    2014 LSV
    2010 Outback V - Sold
    1993 Echelon
    Tough spot to make the wires invisible.
    Jul 2010
    Vicksburg, MI
    Default Re: Speaker Mount
    It is more than clear that Skiers Choice doesn't care about making wires invisible. If they cared, there would be a hole in the port side upright of the OZ and OZHD tower. Take a look at all the Moomba factory mounted speakers. There are wires hanging out on both sides.
    Joe
    2014 LSV
    1993 Echelon
    Dec 2012
    Ennis, TX
    If you want invisible wires go with Exile!
    Shane
    2016 Supra SE
    EXILED
    6 XM9 Tower
    6 Wetsounds XS650 Cabin
    1 EXILE BIG 12 DVC 2000 watt in a ported box
    1 XM 15.4
    XI 1500.1
    2 MX 30.2
    Wetsounds 420 EQ
    EXILE Blue tooth EXBT4
    Blue LEDs
    Oct 2008
    Central, Arkansas
    Quote Originally Posted by smorris7 View Post
    You had to go there
    Joe hit it right, with no hole in the port side upright of the OZ and OZHD tower most will drill a hole on the outside to jump over to the factory gromment hole, with more wires showing.
    It is not impossible to get them totally hidden on towers without the bracket mounts, just takes patience and a long drill bit going thru the factory grommet hole into the port upright. I have been told the factory has made request for the port upright hole, like the one on the startboard side, but it has not gotten done.
    There are many tower speakers with the wires concealed within the collar, such as Wetsounds or HollowPoint. It won't help in this application if you mount to the flat plate. In any case, new penetrations on the top side should conceal the wires from view from most perspectives. Any 'X' mount should bolt up to the flat plates without much trouble. I'd be more concerned that you have enough stand-off so that the pod clears the surrounding tower.
    have others post up pics with four pods on the oz towers, that plate is horrible for speaker mounts.
    Sep 2013
    Indiana
    Thread revival...
    I'm getting ready to mount the 2 pairs of exile sxt9's on my Oz tower. Planning to just put the first pair where the factory ones are located. Thoughts/suggestions on the second with regard to keeping wires hidden and ease of running wire through the tower.
    2013 Moomba Mobius LSV
    345 HP Surf Motor
    EXILE SXT9's, ZLD
    SUMO 900s, 500 IBS, Flow
    2009 F-150 FX4 Supercrew
    Jun 2014
    Florence, Ky
    Just purchased Exile surf package 2 and plan on doing the same ... Curious where you mounted the second pair? Pics would be great ... Thanks
    2014 Mojo w/Surf Flow
    330 Indmar
    Fresh Air Exhaust
    900 - Rears, 500 - Center, 650 - IBS
    4-Exile SXT9qs, Exile ZLD, Exile Bluetooth
