Results 1 to 4 of 4
Thread: How To Replace Belts?
09-16-2014, 07:39 PM #1
I wondering anyone can tell me how hard it is to replace the belts on 07 OBV? Dealer gave me a quote to Replace both belts. $68 for serpentine belt $18 for other belt and $130 for labor. I think I can do it myself and save myself at least $130 but wanted to check to make sure I can handle it before I start tearing into it.
2007 Moomba Outback V
09-16-2014, 08:08 PM #2
What a rip off. You basically have a car engine, the same exact way you replace the belts on a car is the same method you use to replace boat belts. I would just youtube belt replacement and there should be 100 different videos.
09-17-2014, 03:37 PM #3
Easy to replace. I replaced the serpentine belt a few weeks ago. Bought the belt locally and for about $20. Only issue was I had to take off the water pump to remove the belt. A bit of a pain but well worth it to save money so you can buy more stuff for your boat.
Good luck.
09-17-2014, 11:25 PM #4
You just have to take the two bolts out that hold the impeller pump bracket to the block.
99 Outback LS. Sold
