Results 1 to 9 of 9
Thread: Taken on water?? funky gas gauge
05-02-2006, 05:52 PM #1Member
- Jan 2006
- 30
Seem to be taking in water. Cannot locate the source, any suggestions?
Fuel gauge is all over the place, can't tell what's in the tank, any ideas?
05-02-2006, 06:29 PM #2Senior Member
- Feb 2006
- Fayetteville, GA
- 319
Replying to Topic 'Taken on water?? funky gas gauge'
Check your ballast system (if it drains to the bilge)
Check where the shaft goes through the hull. Should be light drippage from the sealing cord.
I dropped my new outback off at the dealer on Sat for fuel guage problem.
05-02-2006, 07:52 PM #3Member
- Jan 2006
- 30
It does not have ballast but I'll check the others....tx
Let me know the outcome of your fuel gauge.
Cheers,
05-02-2006, 11:58 PM #4Senior Member
- Nov 2003
- MA
- 159
My advice is to give it up on the gas guage. My 2000 Outback LS is all over the place as was my 4 Winns and the Chris Craft before that. The orientation of gas tanks, their shape, chop and the nature of the float systems are just not conducive to accurate readings. Luckily, my lake is small.
Andy
05-03-2006, 01:16 AM #5Senior Member
- Oct 2005
- Central FL
- 791
The gauge problem can be a faulty sensor - not sure how easy it is to replace on your model - check w/ the dealer.. could be a simple cheap fix for some piece of mind.
-J
05-03-2006, 08:58 AM #6Member
- Mar 2005
- Geneva - Switzerland
- 65
My gauge doesn't work exactly either ('05 XLV). But I read it here and in other forums that this is always the same problem on any boat...
I take engine hours as a reference....
Markus
05-03-2006, 09:47 AM #7Senior Member
- Sep 2002
- Pennsylvania
- 106
How much water are we talking about? Is your bilge running for 20 seconds or 2 minuets several times a trip? All boats will take on some amount of water.
As for the fuel gauge: It is frustrating because it bounces all over the place so you may want to keep track of you Hour meter. For instance I have a 2001 Outback LS, with ballast, crew and gear, I’m somewhere around 1500 to 1800 #s and I burn 5 to 6 gallons of fuel per hour in tow. When we are just cruising with no ballast we are around 4 gallons per hour.
Hope this helps, E
05-03-2006, 01:15 PM #8Senior Member
- Mar 2005
- t-town
- 718
Sounds like the excess water is probably a result of the shaft packing needing to be either tightned or replace and if it is lot of water could be a crack in the mufflers.
Doug
05-03-2006, 04:48 PM #9Member
- Jan 2006
- 30
Thanks everyone for your advise and input! very much appreciated
Cheers
Water temp gauge
By gsi09907 in forum General ChatReplies: 7Last Post: 07-03-2007, 06:21 PM -
Ballast Gauge
By Pike in forum General ChatReplies: 2Last Post: 04-17-2007, 07:52 PM -
Gas Gauge
By ward_knutson in forum Service & RepairReplies: 10Last Post: 09-13-2004, 12:15 AM -
Salt Water/Brackish Water Use
By RickMcD in forum General ChatReplies: 2Last Post: 06-28-2003, 11:59 PM -
RPM Gauge
By Danny in forum General ChatReplies: 5Last Post: 04-18-2003, 05:52 PM
