Page 2 of 2 FirstFirst 12
Results 11 to 20 of 20
  1. #11
    Jul 2011
    Murrieta, CA
    Default Electrical whine
    Thank you MLA.
    2018 Max with a little extra weight here and there
  2. #12
    Jul 2011
    Murrieta, CA
    Got everything cleaned up and tidy. Still a slight whine with fuel pump running but seams better. Can't wait to test on the water with the engine running.
  3. #13
    Jul 2010
    Vicksburg, MI
    Default Re: Electrical whine
    Quote Originally Posted by Boonejeepin View Post
    I do not see any fuses. Did you use any?
    Joe
    2014 LSV
    2010 Outback V - Sold
    1993 Echelon
  4. #14
    Jul 2011
    Murrieta, CA
    I did. I have a 200 amp circuit breaker within a foot of the battery switch for the main power line to the distro block and also a fuse on all three power wires going to the amps immediately after the distro block. The fuses for the individual amp power lines are hidden behind the amp board.
  5. #15
    Jul 2011
    Murrieta, CA
    Thanks MMandley for talking me through this today.
    I think I tracked the noise down to the EQ.
    Input from headunit disconnected.
    Phone output direct to amp input rca - no whine
    Jumper rca from eq to amp - whine
    All eq inputs disconnected, rca jumper from eq to amp - whine
  6. #16
    No problem, glad to help
    [COLOR="#696969"]
  7. #17
    Oct 2010
    Lake Wylie NC Area
    Does the EQ have adjustable input sensitivity? If so, how is it and the amp gains set? Higher the gains, the more the system is open to unwanted noise.
  8. #18
    Jul 2011
    Murrieta, CA
    I have a Clarion eq and it has adjustable gains for the aux in. Same noise with the aux gains up or down. Same noise aux RCAs plugged in, or not. Only drop the noise when cabin amp RCA line is unplugged from the EQ.
  9. #19
    Oct 2010
    Lake Wylie NC Area
    Ok, so the main gain is fixed, but the noise is when the EQ is in either main or AUX modes? That puts it on the output side and would make sense if its heard in both the front and rear zones, since its a single output thats split.
  10. #20
    Jul 2011
    Murrieta, CA
    Correct noise for both main and aux modes.
    The noise is really only noticeable now when volume is all the way down and fuel pump is running. I can live with that. It's not really loud at all now.
    I haven't started the engine yet. Hope the loud noise does not show itself then.
