    Mar 2013
    Madison, AL
    Default Perfectpass parts
    Why is perfectpass the only place that carries their parts? Why doesn't skidim or bask line carry the parts? I hate that you have to call perfectpass to order parts. I need a new throttle cable w/ knob. My knob is slipping on the servo motor so it won't auto tighten.
    2005 Moomba Mobius LSV
    ACME 1433 prop (newest upgrade)
    1900lbs Surf side
    Jul 2013
    jonesboro IN
    The knob has a set scew. That happened to mine a few weeks back.
    2000 Möbius V
    Indmar assault 5.7mpi
    Perfect pass stargazer wake
    Oj 445 will be replaced soon
    1100#on each side of the eng ,800 in ski locker
    almost enough
    Feb 2005
    Ottawa, Ontario, Canada
    Very interesting. Is there a symptom wherein the perfectpass will hunt a lot, above the targetted speed, if you try to engage it? Mine has been doing this lately. I thought that it was from moisture in the system, but now it's happening even when I do not neglect to get the cover on before rain.
    2005 XLV, upgraded ballast, Comptech swivel wakeboard and hydrofoil racks, Monster cargo bimini
    Jul 2013
    jonesboro IN
    Are you saying it hunts up and down.
    If so try adjusting the kva in the settings.
    2000 Möbius V
    almost enough
    Aug 2011
    Default Re: Perfectpass parts
    It's probably the servo motor, take it apart and clean it, use some dielectric grease. Will be good as new.. I did this with mine several times, I ended up having to move the servo, it kept getting wet from surfing..
    http://www.mastercraft.com/teamtalk/...p/t-19332.html
    2002 Moomba Mobius LSV - Sold
    2006 Moomba Mobius LSV
