Results 1 to 10 of 13
    Mar 2013
    Madison, AL
    Question Need NEW depth gauge recommendations
    I have re-epoxied mine down and moved it all around and it still doesn't pickup worth a crap. Always getting the (--) or (00) symbols. It will read sometime times though. Im sick of fooling with it!!
    Its the stock one that came with the boat. What is a good replacement/upgrade that everyone is using?? Hopefully I can order one from amazon and comes as a kit. Shouldn't be to hard of an install I wouldn't think.
    Thanks,
    Jared
    2005 Moomba Mobius LSV
    ACME 1433 prop (newest upgrade)
    1900lbs Surf side
    Faria Digital Depth + Air/Water Temp
    http://www.overtons.com/modperl/prod...FbRzMgodPFoAFA
    Don't have one yet, but plan to when the cheapo Uniden finally dies. I'm planning to go with the in hull "eye" vs the glue down "hope it works - hope it stays" thru hull puck.
    Apr 2011
    Andover, KS
    I've had Faria's in previous boats and as far as I'm concerned, they're junk. I have a friend with a Hummingbird that is always spot on! I'm going to go with it when my stock one completely quits.
    2009 Moomba XLV Gravity
    May 2013
    Vancouver WA
    I have a faria with a airmar in hull transducer. I had some frustrations with mine because I first mounted the transducer with silicone to the hull. You fill the base with mineral oil and lock the transducer into it. Mine ended up leaking out some of the mineral oil. So I used JB weld on the inside and outside of the base in hopes of making it not leak out mineral oil anymore.
    That lasted 1/2 a season and then I was having to top it off way too often. So I pulled the base off my hull and the silicone peeled right off. I cleaned everything up and reapplied the transducer base with some 3m 5200 Fast cure. That finally did the job and seems to be working great.
    That said, if I was to do it all over again, I'd probably get a thru-hull transducer (getting water temp would be a bonus, although I already get water temp with my Perfect Pass paddlewheel).
    I don't like the fact that the LED backlighting is integrated into the Faria gauge and can't be changed. It's not bad with the red backlighting, but it doesn't match anything else I have.
    The reason I went with the Faria/Airmar combo is simply because the previous owner of my boat bought it and never got around to installing it and included it with the boat purchase...
    Apr 2014
    Just installed humminbird hdr650 excellent product.
    2014 Outback V
    Mar 2014
    Park City, Utah
    I will second the 650.
    2013 Supra SA450
    2006 Mobius LSV - Sold
    2004 Stingray 190LS - Sold
    www.tffor.org
    I'll be curious to hear about your experience with the hdr650.
    My crapola Uniden was up to its tricks again this weekend (3.5ft, no 163ft, no 34ft, no...) although I'm wondering if it acts flaky when there is more water in the bilge. It shouldn't but now I'm suspicious if there's some cause and effect going on there.
    May 2013
    Vancouver WA
    I had to refill my transducer with mineral oil when I went to lake Merwin... Having that mineral oil FULL in there seems to be pretty key to making it read accurately for me.
    Aug 2005
    Saskatoon ,SK
    how do you fill the transducer ???Have not had a working depth gauge for years now also see the --- . Removing old transducer is next option .
    May 2013
    Vancouver WA
    Quote Originally Posted by freyse View Post
    So, on my depth gauge, there's a wired transducer that has a baseplate that is affixed to the hull. The pieces look like this:
    In this pic, the baseplate is the piece on the right, and the transducer is upside down on the left.
    Once it's assembled, it looks like this:
    The transducer snaps into the top of the mounting piece. The mounting piece is really just a tube with a flange on the bottom and a mechanism for the transducer to snap into it at the top (with an o-ring to seal that connection). The mounting piece is open at the bottom. The flange is what is affixed to the inside of your hull. I used 3m 5200 fast cure to affix mine.
    Actually, this is a great picture of the two pieces that I have.
    So, because the bottom of the tranducer isn't touching the hull itself, you fill the base piece with mineral oil. That way it's not shooting through a pocket of air before it goes through the hull and the water. Mineral oil is used because it's thicker...
    I don't know what type of transducers are in other boats, but this is how my wired, no-drill one works.
