Results 1 to 10 of 18
    Apr 2014
    Tifton,GA Lake Blackshear, and Lake Cheehaw
    Default Drivers seat riser tube
    Does anyone know where to get a taller riser tube. I would like to raise my drivers seat and was wondering if you can just get a longer tube anywhere?
    2015 Supra SG 450 Fire Red Metallic
    Wetsounds and MMATS
    2015 Mojo
    2014 LSV
    2006 Tahoe Q4sf
    By tube do you mean a pedestal?
    I'd like to find a slightly taller one or even adjustable one. But mine is very short to begin with and haven't found scratch when I've looked.
    Apr 2014
    Yes just the tube. I've looked just came up empty. With heavy weight and an ibs the nose is high even with the bolster folded it is still hard to see.
    Wetsounds and MMATS
    2015 Mojo
    2014 LSV
    2006 Tahoe Q4sf
    Gotcha. Most of the ones I've come across start at 12" height and go up for there. No bueno...
    http://www.attwoodmarine.com/store/c...l-eze/seasport
    Jan 2014
    Sherwood, OR
    I need one as well. I am 6'3" but the wife is 5'6" and struggles to get good visibility. And you know what that means for me = shorter sets behind the boat.
    2014 Moomba Mondo - Exile Tower/Sub/ZLD/EXBT4/Amps (2x), Hertz Cabin - Evolution Cover - 650 IBS, 900s Rear, Center Hard Tank, Flow
    1969 Bayliner Tahiti - 120 HP Force Outboard - Gone but not forgotten
    -CJ
    replace it with an adjustable one
    http://www.overtons.com/modperl/prod...destal&i=28277
    raise the bolster & put your throwable flotation device on top of it.
    Jul 2014
    Chenoa, IL
    I sit on my throwable flotation device as said above.
    2003 Moomba Outback with 283 hrs on the 310HP Indmar. Its in Cherry condition also and now we will again start to use the boat after a few years off.
    Anyone else driving usually likes the throwable - I don't. I may just add some aluminum rails between the base and seat to give it a lift. Adjustable would be nice though...
    In hindsight I REALLY wish I would have sprung for an aftermarket seat with Bolster in it prior to the new upholstery job...
    would those ajustable ones be a bolt in thing or do ya think there would be some fabricating going on on to make them fit?
    2013 outbackv
