Results 1 to 3 of 3
    Apr 2014
    Owensboro, KY
    Default 2008+ XLV hull changes?
    Were there any changes to the XLV hull after 2008? I know that they recieved a drain plug but is that all?
    Jul 2011
    Murrieta, CA
    I think 2008 was the last redesign of the XLV. The 2010 got reversible ballast pumps.
    http://www.wakeboardingmag.com/boats...bius-xlv-2008/
    Hull: The 2008 Moomba Mobius XLV’s updated hull design does more than create better wakes. It also offers quicker planning and better fuel efficiency, thanks to new positions for the lifting strakes that help the hull displace water with less resistance. But the real benefits are found behind the boat, where changes to deadrise and rocker create a better balance of transition and vertical lip.
    2010 Moomba XLV
    340hp cat
    Gravity 3, wake plate
    Rad-a-cage
    1100 v-drive lockers
    1180 under the playpen
    Jan 2014
    Texas
    2009 xlv also had reversible pumps.
