Results 1 to 6 of 6
    Aug 2002
    Corpus Christi, Texas
    Default Outback Propeller
    I want to purchase a spare propeller for my 1999 Outback. There are several propeller shops her in Corpus Christi but I need the specifications for the OEM prop. I have the 3 blade. Thank you.
    Bobby
    Apr 2003
    Powhatan, VA
    Default Prop
    Mine uses a 13 by 13 LH prop and the shaft size is 1 ".
    Your existing prop may have markings on the end of the brass hub that might be visible up close.
    You could check Overtons.com and SkiLimited.com on-line to compare prices. They will ship right to your house. I got one from the second place.
    Consider carrying a 1 1/16" wrench or big adjustable, a prop puller, and spare nut, washer, square keyway key, and cotter pin if your mission is to carry a replacement "just in case"...
    Also, a medium sized metal file ( mill file ) is sometimes needed to tweak the key to fit the slots on the shaft and prop....
    Good luck!
    Feb 2003
    idaho
    Default prop
    I just replaced my'98 mobius prop with an acme. For wakeboarding it is faster out of the hole and may have 1 or 2 less MPH top end. I bought it at propellors online and they have a table that tells what you need (matches OEM or upgrades) I can look at the numbers if you don't find yours on your current prop. I'm sure it is an o johnson 13x13 with some pitch number. Look near the shaft and you'll find those numbers.
    2005 XLV
    gravity 3
    perfect pass
    Guest
    Default <a href=''
    funny ringtones
    Default Replying to Topic 'Outback Propeller'
    I have a '99 outback... I have a 4 blade prop.... It is 13 X 13... If I am not mistaking... I had a really hard time getting it off... I bent the tips when I hit something in the river... I had to buy a prop puller to get it off... I heated it slowly and used a piece of wood to try and get it off... I tried 2 c clamps... Nothing worked... So I spent 119 dollars for the prop puller.... It came off with ease.... I then used a brass hammer and a piece of wood and gently taped it back in place... But I love the four blade... My top in is 40 to 41 mph.... Hope this helps.
    Jun 2006
    I replaced my OJ 13 X13 4 blade on my 04 Mobius with a three blade ACME 543, this thing did wonders for my boats perfromance.
  1. Propeller for a XLV GG
    By TobesDubai in forum Sales & Information
    Last Post: 01-18-2007, 12:01 PM
  2. Propeller
    By alex in forum Wakeboarding | Wakeskating
    Last Post: 06-17-2006, 07:48 PM
  3. Propeller
    By ben624 in forum General Chat
    Last Post: 04-07-2006, 08:50 PM
  4. WHICH PROPELLER
    By Patton in forum Service & Repair
    Last Post: 07-20-2005, 12:45 AM
  5. Propeller
    By in forum Boat Owners
    Last Post: 05-18-2003, 09:35 PM
