Results 1 to 10 of 11
    Aug 2014
    Tacoma, WA
    Default New to Boating Purchase HELP
    Hi Everyone!
    Im New to this forum and im very thankful for all the help its given me so far. Im looking to buy a wakesurf/wakeboard boat and I found a 2007 Moomba Outback V for 24500. I have a hesitation with this boat because the compression test was as follows:
    Cylinder 1- 130psi
    Cylinder 2- 125psi
    Cylinder 3- 120psi
    Cylinder 4- 120psi
    Cylinder 5- 165psi
    Cylinder 6- 160psi
    Cylinder 7- 120psi
    Cylinder 8- 150psi
    also the alternator seized during the mechanical inspection due to corrosion and the tech was able to free it... for now.
    I guess what Im asking is if this is normal or too low for a motor with 350 hours on it. do you think I could get more bang for my buck with something else?
    Des Moines, IA
    Do you have any more room in your budget?
    Aug 2014
    Tacoma, WA
    not too much I want to keep it around 25k
    Des Moines, IA
    I would keep looking. That's a big difference between cylinders.
    Jumping to an 06 or 07 LSV would be my suggestion if you can find a way to swing it. At the end of the season I bet you'll see some great examples in the higher 20s. It would be a more upfront but I think you'd be glad you did it.
    The outback is a great boat though and I think you'd be happy with it as well. Either way, hopefully we can welcome you to the family soon.
    Apr 2014
    Roanke, VA
    Ill sell you my Mobius for 14500 . solid boat, great motor, low hours.
    Yellow over White 99 Mobius 21'open on jet black double axle
    Aug 2014
    Tacoma, WA
    thanks guys, the seller is going to get a second opinion on his own, he was as surprised as I was when we saw the results. there's others out there, hopefully with less saltwater damage
    Welly72,
    I'd love to check out your boat! just a little far for me...
    Des Moines, IA
    Salt water and low compression? Run.
    Dec 2006
    Tuscaloosa, Alabama
    Quote Originally Posted by BigShizz View Post
    Welly72,
    Salt water? Not me. I know first hand what salt water does when I had my other boat.
    Jack Beams
    '05 Outback DD
    325HP EFI Indmar
    De Pere WI
    salt water would be an immediate no-go for me, no matter the hours or condition.
    Jun 2014
    Florence, Ky
    One of my friends purchased a boat that was supposedly in salt water once and two years later spent $5k for motor replacement.
    2014 Mojo w/Surf Flow
    330 Indmar
    Fresh Air Exhaust
    900 - Rears, 500 - Center, 650 - IBS
    4-Exile SXT9qs, Exile ZLD, Exile Bluetooth
Tags for this Thread
