Results 1 to 10 of 15
    Apr 2009
    Default Wiring diagram for '02 LSV
    Trying to locate a wiring diagram for a late 2002 mobius LSV Carb'd engine. Any help would be appreciated. Mainly engine, found one on the forum but just for fuel pump.
    I bought the boat in very bad shape. Trying to get it going again, so far new engine, prop, shaft, rudder, tracking fins, dripless seal, fiberglass repair, and still at it. Found that the last owners butchered the wiring harness. It was beached on a rock.
    Great forum! I don't post but read a lot of great information.
    Aug 2011
    Default Re: Wiring diagram for '02 LSV
    What are you looking for? I have them somewhere, or send ACooper@skierschoice.com a polite email and they'll send them..
    2002 Moomba Mobius LSV - Sold
    2006 Moomba Mobius LSV
    Aug 2011
    Apr 2009
    Parrothd, thank you. I am needing the engine harness, example, found 12v wire from oil pressure switch to thermostat. Hooked battery up thermostat went off like a shotgun. Found thermostat wire tied into starter wiring...
    Thank you for the diagrams but they don't match up, I was told my 2002 LSV was the pre-production 2003 LSV if so not sure if it matters.
    Thank you for your help. Took vacation this week to try and get it going and in the water.
    Aug 2011
    Email skierschoice..
    Apr 2009
    Just emailed them. Thank you for your help.
    Aug 2014
    conroe, tx
    i emailed a. cooper at skiers choice and was told they dont have a wiring diagram for the engine. also contacted indmar and they told me to take my boat to a dealer so they could hook up the engine to a diagnostic computer.....the wiring diagram in this thread is very hard to read and is for a 2002, dont know if they are the same....
    Aug 2011
    Make you wonder about the indmar guy, it's carbed there's no computer...LOL...
    There's on a few wires, it's the same as a carbed car engine, what are you trying to fix?
    Aug 2011
    Fyi..
    There's a diagram in the fuel pump thread..
    Apr 2009
    Thanks. I saw the fuel pump thread but it is different. I contacted skiers choice and looks to be a tweener, built in 02 based on 03. I bought the boat and the wiring had been hooked up wrong and re-routed when they put a short block n it. When I hooked the battery up found a hot wire going to thermostat sensor, thermostat sensor hooked to starter. Just trying to make sure I hook everything up correctly. Mainly trying to determine if the 12v wire from my oil sensor goes to starter, fuel thread shows it does but the wire color is orange.
    Thank you for all the help.
