Results 1 to 6 of 6
    Jul 2013
    North Mississippi
    Default Chickens in engine compartment...
    Ok, at least it sounds like chickens...or my kids say squirrels. Anyways, I believe my belt is slipping. Happens usually when I first start up or ease into the throttle. I've seen a few threads on replacing one, but I want to see if there's anything else I should be checking and also if anyone has a part number for the belt for my engine. 2008 Assault 325 (fresh water).
    Steve
    2008 Mobius LSV
    1100#er's in the lockers
    ski locker sac
    IBS
    Johnson reversibles
    Dec 2006
    Tuscaloosa, Alabama
    No number on the belt? That number can be crossed.
    Jack Beams
    '05 Outback DD
    325HP EFI Indmar
    Nov 2009
    Gatineau, Quebec
    Usually when the belt starts to squeak it has worn a bit and lost its tension , you can tighten the tension and or replace the belt if aged .
    2012 Mobius LSV
    05 Outback LS SOLD
    May 2013
    Figure out which belt it is by putting some wax on each one till the sound stops. Check the tension and new rust on a pulley. Being a boat that probably sits for periods of time, corrosion can build on a pulley and cause the squeal till it is worn down again.
    Heat up the BBQ, get out some lemon pepper or perhaps buffalo sauce and then... Oh wait, belts...
    If you pull it off and take it along to an auto parts store they usually have a gauge thing where they can stretch it over to get a size and find something compatible. Don't take it to a marine shop. The same alternator belt will go up $20 if you say it's for a boat.
    Jul 2002
    London Ontario Canada
    I just replaced my 09 belt, took about 20 mins, I used good year gator back. Search my name ,it was a 26$ belt
    09 21v LAUNCH
    99 Outback LS. Sold
    Doug
