Results 1 to 9 of 9
Thread: Seat removal
    Jun 2014
    Fresno, Ca
    Default Seat removal
    What's the trick removing the seat on an 06-08 obv, 05- möbius? My anchor screws look like they're tamper proof. Looks difficult unless they aren't too tight.
    2006 Outback V
    1992 Ski Nautique Open Bow
    Eugene OR
    If you are talking about the drivers seat, on my 08 OBV there is just 4 bolts under the cushion. Once you have the 4 nuts removed seat pulls up.
    Quote Originally Posted by jester View Post
    yep, pull the seat cushion.
    Jun 2014
    Fresno, Ca
    What I'm referring to is the seat base. I should have been more clear.
    2006 Outback V
    Oct 2009
    Wisconsin
    Quote Originally Posted by valleywine View Post
    Seat base is mounted to the floor board. Why do you want to remove?
    Jun 2014
    Fresno, Ca
    Quote Originally Posted by 2007 Outback V View Post
    I'd like to raise it some and replace carpet with something else.
    2006 Outback V
    Oct 2009
    Wisconsin
    I'd build a riser bracket to raise the seat.
    Pull the entire floor to replace the carpet. It's pretty easy to do, follow the perimeter removing all the screws. Need two people to lift it out easily.
    Jun 2014
    Fresno, Ca
    So on my boat the seat base is part of the fiberglass floor so no way to detach. I ended up Using some of my kids old skateboard wheels and longer bolts. It raised the seat approx 2 inches. I'll have to see how it feels this summer as I did this adjustment after I winterized the boat. It feels better just sitting in it though.
    2006 Outback V
    You'll be happy. My swivel mod moved mine up about 2 1/2" and it's way better.
