Page 1 of 4 123 ... LastLast
Results 1 to 10 of 32
    May 2014
    Hoover, Al
    Default New surfer , any advice welcome
    Aug 2011
    Default Re: New surfer , any advice welcome
    How fast you going? Looks like 80... Lol..
    2002 Moomba Mobius LSV - Sold
    2006 Moomba Mobius LSV
    May 2014
    Hoover, Al
    11.1
    2900 rpm
    2012 Mojo
    May 2014
    Hoover, Al
    2900-3000 rpm is where the wave cleans up
    2012 Mojo
    Aug 2011
    That wave doesn't look good, maybe one of the others can give some advice. Seems way to fast and more weight on Surf side, probably start at 9 and work up to 11?
    You need to stand up with equal weight on both feet..
    If you check my youtube channel there's lots of Surf videos..
    http://youtu.be/HiVUijedY2A
    11.1 mph is fine for the Mojo, but you need the right ballast setup. For regular, 1,100 full on surf side, 370 under port seats, off side at least 1/2 full, center tank full and IBS full. Wakeplate 75-100% up.
    May 2014
    Hoover, Al
    I am all the above except no 370 added port
    That may be what I'm missing
    It is much better with two adults on port
    2012 Mojo
    Jul 2013
    North Mississippi
    Looks like you're pretty far back in the wave pocket, less push back there. Also, stand up taller and use 2 hands on the rope...I'm exhausted just watching you..plus I bet your arm is burning. Finally, remember your front foot is the gas pedal and your rear foot (right) is the brake. Try shifting at least your front foot (left) more forward on your board if not both feet slightly more forward. It's a constant shifting/leaning of weight forward and aft on your board and fine tuning foot position.
    2008 Mobius LSV
    1100#er's in the lockers
    ski locker sac
    IBS
    Johnson reversibles
    May 2014
    Clermont, Fl
    at the very least - if the driver isn't the videographer - get that person to sit on the surf side!!!
    1st thing I would suggest is to pull yourself into the wave instead of staying on top of it and the majority of your body weight is over the center of the board - and yes it does look like your going way too fast.
    Apr 2014
    Lean forward on the board means you're on the gas
    Lean back and you're on the brakes.
    if you lean way forward (toward the boat) you will eventually accelerate all the way to the swim platform. If you stay leaned back (away from the boat) you will fall out of the wake completely. mix the two together to stay where you want in the wake.
    2002 mobius LSV
    Lake Minnetonka, MN
