Results 1 to 10 of 15
Thread: Where do you buy your oil?
04-17-2006, 02:39 PM #1
I recently bought a 2000 Kamberra and want to change the oil for the first time. I looked in the Indmar Owner's Manual which has suggested Penzoil Marine 15W40, the problem is I can't find it anywhere. Do you guys order it online? Suggestions?
Also - they leave the option of using synthetic up to the owner....what do you use?
thanks in advance!
04-17-2006, 05:34 PM #2
Replying to Topic 'Where do you buy your oil?'
At last check (january 06), Wal-Mart had pennzoil marine 15w-40 for 1.74 a qt. I bought a case (of Budweiser), then went a got me 5 quarts of oil. BTW, the Fram oil filter number is PH-30 for those interested.
04-17-2006, 07:25 PM #3
i get mine at wal-mart also
Hey, Its Moomba time
13 Mobius LSV-sold
08 Mobius LSV-sold
03 Mobius LSV-sold
04-17-2006, 08:45 PM #4
Ah you gotta love WalMart. Tube tops with chili mac stains and elastic pants...and that was just the guy working the Hunting and Fishing counter. What would we do without it.
Walmarts the only place Ive ever found it.Jim Hagen
Madison, Wisconsin
facebook.com/signedgewraps
2011 Moomba Mobius LSV - Exiled
2002 Moomba Mobius LSV - Sold
04-17-2006, 09:17 PM #5
Just remember that there is a difference between 15w40 Marine oil and 15w40 Diesel engine oil. Make sure you know what you are getting. It is my understanding that you do not want to run the Diesel oil in the Marine engine.
DaveIf you believe something to be true, it will be - in it's consequences.
04-18-2006, 11:08 AM #6
Thanks guys
I will go tonight.
04-18-2006, 12:38 PM #7Member
- Jan 2005
- 60
The local Moomba dealer recommeded Delo 15W40 available at NAPA
DeloŽ 400 Multigrade Heavy Duty Motor Oil 15W-40 Performance
First oil to allow the diesel engines of the three leading U.S. manufacturers to run for over 1,000,000 miles without an overhaul.
It exceeds the tougher performance standards for the new API CH-4 service classification of modern, electronically controlled, low-emission engines.
It exceeds the performance requirements of the Mack EO-M Plus, Cummins CES 20076 and Volvo VDS-2 specifications.
Its exclusive ISODEWAXING technology rivals synthetics in critical engine tests.
It offers an optimal blend of dispersants, detergents, oxidation inhibitors, antiwear, corrosion inhibitors, viscosity improvers and defoaming additives
Will
04-18-2006, 12:40 PM #8Senior Member
- Mar 2005
- t-town
- 718
Will, What filter did they recommend.
Doug
04-18-2006, 12:43 PM #9Member
- Jan 2005
- 60
I use the standard Fram PH-30 (same as earlier post) in my 05 LSV 350 EFI.
Will
04-18-2006, 12:49 PM #10Senior Member
- Mar 2005
- t-town
- 718
Will, That is what I used in my old outback and was just curious if there was something better.
Doug
