    Apr 2013
    Dallas, TX
    Default 2013 LSV swim platform movement
    Any suggestions on how to stop my swim platform from moving up and down while both just sitting in the water and while surfing? I've tightened the screws on both sides and it still moves up/down about an inch. I recently added a FEA and its bolted to the platform and so it moves too. Thought about shims on the top side of the mounting bracket. I can hear the platform rattle a bit while surfing.
    DaveM
    2013 LSV 330HP
    Jul 2002
    London Ontario Canada
    I take a washer that will fit between the bracket and holder at the top , then bend the washer with 2 vice grips so you can remove it in the fall. I others have used lock washers so they don't fall completely down in the gap
    09 21v LAUNCH
    99 Outback LS. Sold
    Doug
    Jun 2009
    South West Colorado
    I use composite door shims and break them off when tight.
    I don't pull the platform off much, but the shims can be broken up to remove, if need be
    '08 Mobius LSV, Mods- 1100 lb Rear Sacs, IBS Sac, Center 400 Sac, Dedicated thru-hull intakes and pumps per sac, SeaDek One Piece Mica over Black Roo, EZ Net Cargo Nets, Swivel Drivers Seat, Hot Water Shower, Hinged Wind Block, Bow Cushion Adapter Plate for Drink Holders Access, etc, etc.
    Dec 2012
    Ennis, TX
    Shims are the only option other than going to the 2014 brackets.
    Shane
    2012 Mojo 2.5
    EXILED
    6 XM9 Tower
    6 SX65M Cabin
    1 XI 800.4
    1 XI 1500.1
    2 MX 30.2
    EXILE ZLD MKII
    EXILE Blue tooth EXBT4
    Green LEDs
    Dec 2012
    Ennis, TX
    You will want to replace the Allen screws with stainless bolts ASAP. If not you will have bent, broken or stripped set screws. Gonna want to replace those pins also. They will fall out occasionally.
    Shane
    2012 Mojo 2.5
    EXILED
    6 XM9 Tower
    6 SX65M Cabin
    1 XI 800.4
    1 XI 1500.1
    2 MX 30.2
    EXILE ZLD MKII
    Green LEDs
