Results 21 to 30 of 31
07-12-2014, 12:30 PM #21Senior Member
- Jan 2014
- Kelowna, BC Canada
- 426
07-12-2014, 12:36 PM #22
Just received my boat .... batteries not connected?? HELP!
Well, I'm not sure what switch you have, but did you connect the wires to the battery switch or were they already terminated? My concern is where you show one battery connected to post 1 and the other to post 1+2. Is that correct? I would expect battery 2 to be connected to post 2, not 1+2. I am not 100% on that though. If it was already connected to the switch before you took ownership, I would not mess with it for now.
On the negative/ ground side, it looks good. Nice job!'08 Mobius LSV- SOLD!
2017 Mojo Pro
07-12-2014, 12:40 PM #23
On second glance at your first post, I think you are good with the switch connections. You mentioned that you got power on both position 1 and 2, which I think means the batteries are terminated where they should be. Maybe someone else had more insight on the dual battery switch that comes on the new boats.
2017 Mojo Pro
07-12-2014, 12:53 PM #24Senior Member
- Jan 2014
- 426
07-12-2014, 12:54 PM #25
Have fun. Good luck!
2017 Mojo Pro
07-12-2014, 01:17 PM #26
He has it correct. The labels on the front of the switch are deceiving. If you look on the back side of the switch, you will see that battery 1 post is behind battery 1, battery 2 post is behind battery 1+2, and the common post is behind battery 2.
Joe
2014 LSV
2010 Outback V - Sold
1993 Echelon
07-12-2014, 03:20 PM #27
You need to dismount the switch and make absolute certain that the cables are connected correctly. On both the Perko brand and Blue Sea brand switch, both widely used, the battery cables are opposed and the common is in between them. Based on your diagram, and im ignoring the nomenclature on front as it does not translate directly to the back, your main battery cables are incorrect.
The batteries' main B+ cables should each terminate to the #1 and #2 labeled post, and ALL output cables go to the "C" post.
07-12-2014, 04:11 PM #28
Re: Just received my boat .... batteries not connected?? HELP!
Joe
2014 LSV
1993 Echelon
07-12-2014, 05:27 PM #29
07-12-2014, 05:45 PM #30
Ok, quick look online at the most common Perko and Blue Sea 9001E, the batt-1 and batt-2 posts are opposing each other. But, on the Blue Sea 6007 Mini, you are 100% correct, the #1 and C are opposing each other, and the #2 is below/center of those two. I think the OP's switch is wired correctly, its just the labeling on above diag does not correlate with the back of the switch, and could be misleading.
