Results 11 to 20 of 31
07-12-2014, 02:15 AM #11
Just received my boat .... batteries not connected?? HELP!
That would likely be a ground and would create the issue you are having, if not connected. Does it look as though it could have been connected to the negative wingnut of one of the batteries?
'08 Mobius LSV- SOLD!
2017 Mojo Pro
07-12-2014, 02:42 AM #12Senior Member
- Jan 2014
- Kelowna, BC Canada
- 426
that was it! stereo works fine now ...
i followed that loose wire and it went to the amp.
there is another loose black (same connector on the end) that cannot connect to anything. i followed it as far as i could and it looks like it goes down into the boat.
any idea what that one could be?
07-12-2014, 02:45 AM #13Senior Member
- Jan 2014
- 426
Oh and also ... maybe this is normal not sure ... but when the key is turned in the RUN position the CHECK ENGINE light is on.
07-12-2014, 09:18 AM #14
Check engine light turns on until motor is running.
2017 Mojo Pro
07-12-2014, 09:20 AM #15
That other connector likely is ground for other accessories. Are you saying it doesn't reach the batteries/ isn't long enough?
2017 Mojo Pro
07-12-2014, 11:15 AM #16Senior Member
- Jan 2014
- 426
No it definitely will reach. Just not a spot for it unless i attached 2 grounds to one terminal?
07-12-2014, 11:31 AM #17
There would be nothing unusual about doing that. Obviously want to make sure it's a ground not a power.
Kevin
2012 Launch 242
07-12-2014, 12:03 PM #18Senior Member
- Jan 2014
- 426
and ground connections are the small connectors beside the negative terminal right? Which battery would I connect it to? B1 or B2 or does it matter?9
07-12-2014, 12:25 PM #19
On the ground side, It really doesn't matter, as the two batteries are connected together via the ground link that you show in your drawing (ideally, you would take it to one battery or the other for ground loop purposes, but that's not a big deal for now- don't worry about it.)
No problem connecting two leads to one connector on the battery. The fact that the cable in question is black and that is goes straight into the depths of the boat floor without going through a circuit breaker or fuse tells me it is likely a ground. Go for it.Last edited by moombahighrider; 07-12-2014 at 12:28 PM.
2017 Mojo Pro
07-12-2014, 12:26 PM #20
Ground and negative terminal are the same- just multiple terms for the same thing in the 12volt dc world.
2017 Mojo Pro
