Results 41 to 50 of 251
09-27-2014, 09:43 PM #41
Replacing carpeted flooring with HydroTruf?
Your carpet looks a lot better then mine did too.
2008 LSV on the way out
'17 CRAZ!!! on the way in
09-27-2014, 09:51 PM #42Senior Member
- Jun 2007
- 883
2006 Moomba Mobius LSV
Stereo: Kenwood KMR-D562BT
Ballast: 750 Surfside locker, 400 Surfside mid boat, 400 Gravity I, 400 Bow
Surfboards: Inland Surfer Red Woody, Triple X Composite X 58"[/SIZE]
09-30-2014, 04:01 PM #43
If that were my floor I'd be peeling the carpet off the edges and adding a strip of something to the floor panel(s) for more length, then pull the carpet back over and reglue. Something to fill the spaces from under the carpet and make those gaps vanish.
10-14-2014, 12:06 PM #44
Half way done. I'll get some better final pics when it's complete.
For those of you wanting the do this it's a lot easier than it looks. The best thing is if you think of it as carpet and fold the turf around all the edges like the carpet is. There's no real need for perfect cuts because they'll be hidden under or between something. The only perfect cuts are where you'll have to join two pieces togeather. Because of the turf doesn't come long enough for the whole floor I'll have to have three seams.2008 LSV on the way out
10-14-2014, 12:10 PM #45Senior Member
- Aug 2011
- 2,522
Re: Replacing carpeted flooring with HydroTruf?
Looking good..
2002 Moomba Mobius LSV - Sold
2006 Moomba Mobius LSV - Sold
10-14-2014, 01:13 PM #46
Looks great. I just finished mine last week. Did you use the soft or stiff material? I didn't know there were two versions when I ordered the hydroturf, but I guess there is.
IMG_0200[1].jpg2006 Outback V
1992 Ski Nautique Open Bow
10-14-2014, 02:06 PM #47Senior Member
- Aug 2011
- 2,522
They even sell 1/4in to 2in(?)under padding to make it even softer..
10-14-2014, 04:23 PM #48
I'm using the Molded Diamond on mine because from all the reading I did from the jet ski guys the molded is the strongest. I guess some guys with the cut Diamond had the replace about every season or two but the molded stuff lasted several years. I hope I'm not as ruff on my floor as they are.
There are different soft vs stiff material but from what I understand the soft stuff is like the kind that goes on surfboard and isn't suited for flooring.2008 LSV on the way out
10-14-2014, 04:24 PM #49
10-25-2014, 04:07 PM #50
Done. Pretty much
