Page 15 of 26 FirstFirst ... 5131415161725 ... LastLast
Results 141 to 150 of 251
  1. #141
    Aug 2011
    Default Re: Replacing carpeted flooring with HydroTruf?
    I don't remember it getting hot, warm yes, I've always had black hydro so the Grey should be fine..
    2002 Moomba Mobius LSV - Sold
    2006 Moomba Mobius LSV - Sold
  2. #142
    Nov 2013
    West of ATL
    Well all done. Pretty happy with the results. As for those asking if it gets hot well.... YES IT DOES. I've been in the boat all day finishing up the hydro, 89degrees, full sun, and no clouds. I stopped for lunch and went back out to finish up and couldn't tell which was hotter the vinyl or the hydro. Tip toe hot.
    I can imagine however if you were jumping in and out of the water than it should be ok.
    2008 LSV on the way out
    '17 CRAZ!!! on the way in
  3. #143
    Nov 2013
    Kansas City, MO
    Just sent in my order with Joe. Super excited to get crackin!
    2007 LSV
  4. #144
    Aug 2009
    Montana
    Quote Originally Posted by Rakkasan View Post
    I think that is where DECKadence or miners moss is really beneficial. I don't think it holds the heat as much being weaved mesh? I do like the looks of the hydro, seadek, softgrip floors though. Nice and clean installs. You guys need to report back in a year or 2 on how they hold up.
    2015 "NOT A MOOMBA"
    Why Not? Play Hard! Get wet
  5. #145
    Aug 2011
    Mine came in today..
  6. #146
    Jun 2014
    Fresno, Ca
    Quote Originally Posted by 996scott View Post
    That really looks sweet. Maybe it is my eyes but is the one section installed in the wrong direction?
    I'd tell everyone you installed that section in that direction so the water flows to the center, then back towards the rear. Looks awesome!
    2006 Outback V
    1992 Ski Nautique Open Bow
  7. #147
    i like the look of that in the rear..
    anyone have a source for Canadian purchases?
    Stereo: Kenwood KMR-D562BT
    Ballast: 750 Surfside locker, 400 Surfside mid boat, 400 Gravity I, 400 Bow
    Surfboards: Inland Surfer Red Woody, Triple X Composite X 58"[/SIZE]
  8. #148
    Well after putting down two coats of bed liner in the rear lockers I didn't like how it looked with all weird dents and bumps on the floor. So I just used the rest of my hydro and put a strip in the middle to kind of break it up. All most done just need some trim and after putting the engine doors back in I'll be all done and ready for the season.
    what did you use where the carpet meets the hydroturf? that black seal looking stuff
    also, does anyone have dimensions of the rear storage lockers off hand? just approximate? length and width for ordering sheets of hydroturf.
  9. #149
    Nov 2013
    West of ATL
    Quote Originally Posted by spyder View Post
    I had the bed liner on the bottom and cut up two inches on the sides so the water could move out and not soak the carpet on the sides. That's the black you see on the first pics. When I put down the hydro I added a two inch strip of molded diamond on the sides just to tie it all togeather.
    The size of the lockers are approx 50" long and 26" wide.
  10. #150
    ahh ok, i see now what you did.. thanks for the response! how did you glue it down? and do you think it will stop water from getting below the hydroturf and getting mouldy?
