Results 1 to 8 of 8
Thread: NAV Lights
07-06-2014, 09:50 AM #1Member
- Mar 2014
- Atlanta, GA
- 67
NAV Lights
Was driving home Friday night, and Nav lights quit working. I noticed the lighted toggle switch was off, and then checked all the lights, and they were off. I got in Saturday, and checked the breaker. It was tripped, so I pushed it back in, but nothing happened when I flipped the toggle switch. I kept messing with it throughout the day, and one time I flipped the Nav lights toggle switch, and it shut the radio off. That just happened once, though, so not sure what that was about. I looked under the dash, but it's just a mess of wires. I have no clue what I should be looking for. Any ideas?
07-06-2014, 11:18 AM #2Junior Member
- May 2010
- Western Washington
- 8
NAV Lights
Check under the dash behind the switches. The connections on the switches could be coming loose. It starts with the nav lights, but you could lose the pump and blower. I used a cable tie to keep it from coming apart again.
I have an 03 as well.2003 OUTBACK LSV
07-06-2014, 11:36 AM #3Member
- Mar 2014
- Atlanta, GA
- 67
I'm I looking at one of the plugged connections, or an actual wired connection to the board behind the switches?
07-06-2014, 11:40 AM #4Junior Member
- May 2010
- 8
NAV Lights
On my boat, there is a board that plugs into all the switches, that's what I had coming loose. It was working loose front the center of the boat. That is what I used a cable tie to keep in place.
2003 OUTBACK LSV
07-06-2014, 11:45 AM #5Member
- Mar 2014
- Atlanta, GA
- 67
Ok. Going to check it out, right now. Will post how it turns out.
07-06-2014, 12:08 PM #6Member
- Mar 2014
- Atlanta, GA
- 67
So, the board seems to be pretty tight to the dash. Every time we try to turn lights on, there is a little plastic thing behind temp gauge that lights up, then breaker pops. These related?
07-06-2014, 12:10 PM #7Member
- Mar 2014
- Atlanta, GA
- 67
I pulled the plastic thing out. It is a bulb. Is this my problem?
07-06-2014, 01:09 PM #8Member
- Mar 2014
- Atlanta, GA
- 67
Unfortunately, bulb is not the problem.
