Results 1 to 6 of 6
    Apr 2013
    Default Whistling noise from mondo
    Has anyone heard a whistling type noise coming from the engine at low rpms. As soon as you play with the throttle it comes and goes very weird? I have had it in for it's first service and everything was good. Ideas???
    Jan 2014
    Newberg, OR
    Mine does the same. Salesman said it was "normal". To me it sounds like an air intake or vacuum. The demo boat made the same noise.
    2014 Moomba Mondo - Exile Tower/Sub/ZLD/EXBT4/Amps (2x), Hertz Cabin - Evolution Cover - 650 IBS, 900s Rear, Center Hard Tank, Flow
    1969 Bayliner Tahiti - 120 HP Force Outboard - Gone but not forgotten
    Mine sounds the same it sounds like a throttle body spacer I think it's normal. Sounds cool to me!
    Jordan
    2014 moomba möbius lsv
    Apr 2013
    Thanks for the response thought I was just hearing things.
    Keep an eye on your temp gauge and keep a spare impeller with you. When that thing starts to separate and spin on itself it can sound like whistling. You'll know pretty quick if that's what it is.
    Irondequoit Bay, NY
    could also be the air intake..i personally dont know the sound but could also be it
    Rockford fasgate cabins
    Exile XM7's
    Exile Harpoon
    Exile ZLD
    Polk 10in sub (2)
    Polk P330 amp (subs)
