Results 1 to 10 of 12
    Default 2014 moomba lsv propping help??
    My 2014 moomba lsv has trouble planing out with stock ballast full. Usually about 4 ppl in lounge area of boat. Even with a couple ppl up front sometimes really slow to plane and that's with wake plate all te way down... Have a 537 13.5x16 prop should I be looking at upgrading???
    Jordan
    2014 moomba möbius lsv
    Des Moines, IA
    Yes, call wakemakers - they rock.
    Apr 2014
    Tifton,GA Lake Blackshear, and Lake Cheehaw
    I have a 14 lsv and it came with a 537 and I upgraded my ballast to 1100 in each locker and an ibs. I went with 1273 acme same as 1235 but morr cup to keep your top end. I run 39.8mph wide open with the 14.5x14.25p .150 cup acme 1273. Love it and wouldnt go back.
    2015 Supra SG 450 Fire Red Metallic
    Wetsounds and MMATS
    2015 Mojo
    2014 LSV
    2006 Tahoe Q4sf
    Nov 2003
    Land O Lakes, Florida
    have the factory upgrade acme prop-little sluggish when im running full ballast at and 3000+lbs, for normal ballast its no issue at all.
    Hey, Its Moomba time
    13 Mobius LSV-sold
    08 Mobius LSV-sold
    03 Mobius LSV-sold
    Is that the 537 factory upgrade? Mine was upgraded to 537
    Jordan
    Apr 2014
    The acme options from the factory are 537 and 1235. Standard is oj 14.25x14.5p which is know to growl and I guess another oj that is 14.75x13p which is a bottom end prop for sure. The 537 is a crossover prop more all around for cruising and skiing with a little more topend
    Wetsounds and MMATS
    2015 Mojo
    2014 LSV
    2006 Tahoe Q4sf
    Nov 2003
    Quote Originally Posted by Jrichard1987 View Post
    Jordan
    acme 1235
    13 Mobius LSV-sold
    08 Mobius LSV-sold
    03 Mobius LSV-sold
    Jordan
    So you have the acme 1235? My dealers trying to sell me that one. I plan on running an ibs usually probably have about 2500-3000 lbs ballast in it.
    Jordan
    Sorry meant to qoute moombadaze on that question haha... Newbie
    Jordan
    Apr 2014
    The 1235 will pull that weight just fine you ll just sacrifice a little more top end than you would if you got the 1273. Imoo.
    Wetsounds and MMATS
    2015 Mojo
    2014 LSV
    2006 Tahoe Q4sf
