Results 1 to 8 of 8
Thread: OPS change
    Irondequoit Bay, NY
    Default OPS change
    so im thinking about getting that oil pressure switch for the boat. my question is, when i pull the old one out will oil also come out as well? would like to know so if it does i can have oil on hand so i dont have to go back to the store to get oil ha
    Rockford fasgate cabins
    Exile XM7's
    Exile Harpoon
    Exile ZLD
    Polk 10in sub (2)
    Polk P330 amp (subs)
    Apr 2014
    Roanke, VA
    No there will be oil. It is a switch that messures pressure and when the motor is off there is no oil pressure so it wont leak out.
    Yellow over White 99 Mobius 21'open on jet black double axle
    Irondequoit Bay, NY
    can anyone throw up a pic or tell me where the pressure switch is? i looked around the motor and didnt see it
    Exile XM7's
    Exile Harpoon
    Exile ZLD
    Polk 10in sub (2)
    Oct 2010
    Lake Wylie NC Area
    On a 5.7. it right next to the filter mount.
    Irondequoit Bay, NY
    I'm assuming it's this rusted thing then haha...if it is then I have the wrong ops I bought ha
    Exile XM7's
    Exile Harpoon
    Exile ZLD
    Polk 10in sub (2)
    Oct 2010
    Lake Wylie NC Area
    that is definitely an oil pressure sender for a gauge. If what you bought is small, then its likely for a light/sounder
    Irondequoit Bay, NY
    yeaa..looks like i found the same one on bakes.. (http://bakesonline.com/detail.aspx?ID=1063 ) could be the reason why the boat wont start..its either the OPS is bad or one of the relays..thats what i have come down to. did a jump from the ignition straight to the pump and when u turn the key to on it pumps fuel, so the pump is good. when you try to start theres no fuel pushing out of the injectors..
    Exile XM7's
    Exile Harpoon
    Exile ZLD
    Polk 10in sub (2)
    Irondequoit Bay, NY
    is there a way i can cross ref. the switch with one from autozone?
    Exile XM7's
    Exile Harpoon
    Exile ZLD
    Polk 10in sub (2)
