Results 1 to 10 of 15
    Jan 2013
    Northeast, PA
    Default How to Remove Old Adhesive From Swim Platform
    My new Seadek pad finally arrived today 10 weeks! It seems like it is going to be easy to remove the old hard rubber swim platform. I started pulling up the corner and started pulling, only leaving behind some adhesive. Just wondering what I can use to easily remove the old adhesive and won’t damage the gel coat?
    2007 Moomba Outback V
    May 2011
    Fort Worth
    I would think goop-off or something would take care of it.
    '08 Mobius LS
    Yup goop off, bug removal, mild solvents, wax and buffer will all remove it. just don't use anything to abrasive or to strong like gasoline because it can damage the gell on the deck or the back of the boat if it gets on it.
    Jun 2013
    Huntsville, AL
    Acetone will remove adhesive really well. I used it to remove the adhesive left by the numbers on my old boat.
    1991 Cobia Monte Carlo 188E (Sold)
    2014 Moomba Mojo
    Oct 2008
    Central, Arkansas
    Default Re: How to Remove Old Adhesive From Swim Platform
    I have done 2 platforms using mineral sprits. Soaked the adhedive for about 15 minutes , then scrapped it with a plastic putty blade.
    Sent from my MB860 using Tapatalk 2
    2014 Mojo Surf
    2013 Mojo Sold
    2010 LSV Sold
    2002 OB LSV Sold
    Portland Oregon
    My favorite is 3m adhesive remover. It works well and is extremely safe.
    -Jake
    May 2014
    Clermont, Fl
    I've done this four or five times.
    I have tried all the above and I have found that gasoline and plenty of rags is the easiest and quickest.
    Jul 2012
    Cumming Ga
    I second that method. I would also mention that depending on what type of pad you put back on now is a great time to really buff out the swim platform before you put the new pad on there.
    Quote Originally Posted by mcdye View Post
    Jan 2013
    Northeast, PA
    Mineral spirits and 3M non scratching scouring pad seems to do the trick. I am installing a new Seadek pad that big had to wait ten weeks for.
    Quote Originally Posted by slipperyrockTKE300 View Post
    I do that to clean parts and stuff. Then just throw the rags over the fence into the neighbor's yard or stash them in his garage when he leaves the door up.
