Results 1 to 10 of 10
    Apr 2012
    NKY/Cincinnati
    Default USCG Capacity Sticker for ''11 Mobius LSV
    I need a new capacity sticker for my '11 LSV. Would someone happen to have one handy to snap a picture of and post here? Any model year LSV should be fine.
    Where's the best place to order? Dealer? I was considering printing one myself, is that a terrible idea?
    Nov 2009
    You don't need it so unless you want it for your information it is not necessary.
    http://law.justia.com/cfr/title33/33...3:2.0.1.8.44.2
    -Mark
    "Hey you only live once"
    Aug 2013
    DFW
    I thought it was so he would know where he needed to start the weight at for the ballast. Isn't that what its for?
    Matt
    2021 Mojo
    2016 Mojo (sold)
    2012 LSV (sold)
    Apr 2012
    NKY/Cincinnati
    So are you suggesting our boats are exempt because they are > 20' in length? I pulled this straight out of the Ohio operator's manual. It seems to imply I may get some flak if I get pulled down without one. I could do with as little flak as possible!
    "Capacity Plates
    (ORC 1547.39 and ORC 1547.40)
    No person shall operate or permit operation of a watercraft in excess of
    any of the stated limits on the capacity plate. When no capacity plate exists,
    no person shall operate or permit operation of a watercraft if a reasonably
    prudent person would believe the total load aboard or the total horsepower of
    any motor or engine presents a risk of physical harm to persons or property.
    No person shall alter, remove or deface any information on the capacity plate."
    http://watercraft.ohiodnr.gov/portal...atorsGuide.pdf
    Oct 2013
    Ft. Collins, CO
    The rangers here use it to write tickets for overloaded boats. I got stopped once on my old boat (6 in a closed bow is a pretty full load, 8 might have been pushing my luck) but that boat didn't state a capacity; he let me go based on his judgement that the boat still had good floatation and a V8... and enough life jackets. It has a USCG approval plate but it doesn't state a capacity. That boat is 20.5' so it wouldn't be excluded. Maybe they didn't require these in 1989?
    1989 Sanger Skier DX - sold
    Mar 2003
    Springfield Missouri
    New Guy is correct. You don't need the capacity label. In Washington state you do need the carbon monoxide sticker and they even print it on the registration. Go figure.
    1998 Mobius
    310 HP PCM
    SOLD
    Apr 2012
    NKY/Cincinnati
    Yeah, when I first bought it I got a little carried away with sticker removal waiting to put it on the water!
    This alone wouldn't be a big deal I'm sure w/ most patrol officers, but I'm sure it would only add fuel to the fire should anything else be out of order, or if there's beers on the boat, which is 90% of the time.
    Mar 2003
    Quote Originally Posted by chaneya View Post
    "Capacity Plates
    The rule applies to defacing or altering the plate but is doesn't mention removing the plate. I would recommend removing the plate in such a way that it can be reinstalled when it is sold.
    1998 Mobius
    310 HP PCM
    SOLD
    Apr 2012
    NKY/Cincinnati
    Quote Originally Posted by zabooda View Post
    but... but... it says alter, remove or deface...
    That's the problem, it has been removed and thrown away - so I'd like to have another to put back in its place.
    Nov 2009
    If that is the case call your dealer and have them get one for you. Legally you do not need it and actually I am thinking of pulling it off of our Mojo because we will never be at people capacity but with ballast we'll be overweight. The thing is the Mojo can take a ton of weight and never look overloaded.
    -Mark
