Results 1 to 6 of 6
Thread: Ski Platform Neon Light Kit
04-11-2006, 09:19 PM #1Junior Member
- Jan 2006
- Candler, North Carolina
- 27
I was looking on Wakeside.com and found a neon light tube that is made to be mounted under the ski platform on your boat. I love the idea but I just can't figure out how or where you would run the electrical wire to hook this unit up. If anyone knows how this works, I would love to know. If you can install this product without seeing any visible wires I would love it. Thanks for your ideas. http://www.wakeside.com/page/w/PROD/...atform_led_kit
04-12-2006, 12:52 AM #2Senior Member
- Oct 2005
- Central FL
- 791
Replying to Topic 'Ski Platform Neon Light Kit'
Looks "cool" from view one, but lame from view 2.
VIEW 2
They are LED's not neon, and I'm sure if you dont mind drilling holes in the boat, you can hide wires very easily. Not worth it for the "bling" factor.
-Joe
04-13-2006, 04:26 AM #3Senior Member
- Jul 2003
- 340
I've always wondered if you could eliminate drilling holes for the wiring on these by just using the hardware that mounts the swim deck. You could attach the positive lead to the inside of one of the brackets and the ground to the inside of the other. Then attach the leads from the LED's to the brackets outside of the boat. Not sure if it would work or not, but it may be an easy way to do it without drilling.
04-13-2006, 11:19 AM #4Senior Member
- Oct 2005
- Central FL
- 791
Since most boats are negative ground, having a bolt near the water line with a positive charge would pretty much make a very nice short circuit.
This would be "bad".
-J
04-13-2006, 12:21 PM #5Senior Member
- Dec 2005
- Ontario
- 531
Might make for some good fishing...
2005 Moomba Outback
04-13-2006, 01:24 PM #6
Along with dead batteries and electrolysis on the deck support members.
1998 Mobius
310 HP PCM
SOLD
Light Bar
By tazz3069 in forum Moomba ClassifiedsReplies: 8Last Post: 03-21-2008, 09:29 AM -
Light bar
By chillyx in forum Service & RepairReplies: 2Last Post: 03-16-2008, 10:42 PM -
Installation of light bar
By mobyatBelews in forum General ChatReplies: 1Last Post: 09-30-2005, 02:43 PM -
Light Bar wiring help
By amonteroman in forum Service & RepairReplies: 1Last Post: 08-02-2005, 09:55 AM -
WakeBoard Light Bar
By jekvall in forum Wakeboarding | WakeskatingReplies: 2Last Post: 07-07-2004, 06:57 PM
