Results 1 to 8 of 8
Thread: vapor lock idea?
06-27-2014, 09:10 PM #1
vapor lock idea?
I was walking around work when I had a thought, what if you tap into the fresh water line after the strainer with a small 1/2 inch brass piece and run a small 1/2 hose to the fuel pump and wrap it around the pump and go back into the main line..would that help with the pump being cool or would that not work?
Rockford fasgate cabins
Exile XM7's
Exile Harpoon
Exile ZLD
Polk 10in sub (2)
Polk P330 amp (subs)
06-27-2014, 10:04 PM #2Senior Member
- Aug 2011
- 2,522
Re: vapor lock idea?
Just move the pump..
2002 Moomba Mobius LSV - Sold
2006 Moomba Mobius LSV - Sold
06-27-2014, 10:37 PM #3
vapor lock idea?
Moto, I like the direction you are going. I wonder if it would work, seeing as the issue comes up when the boat has been sitting for a bit after running and the heat soaks in to the pump via the block (the cold water would not be flowing at the time, so I'm not sure if it would be enough to overcome the heat)?
It would be nice to have a way of keeping some cold water flowing around it. A guy could plumb the cold side of a hot water shower to that loop and have it kick on automatically if the boat sits for a certain amount of time after running, maybe...'08 Mobius LSV- SOLD!
2017 Mojo Pro
06-28-2014, 12:42 AM #42004 Outback Blue/white w/5.7 indmar 350, Direct Drive
Exile XM7's
Exile Harpoon
Exile ZLD
Polk 10in sub (2)
06-28-2014, 11:42 AM #5Junior Member
- May 2010
- Western Washington
- 8
vapor lock idea?
If it is an electric pump, may help to put it horizontal vs vertical. I had a problem with vapor lock in warmer weather, made the difference for me.
Sent from my iPad using Tapatalk HD2003 OUTBACK LSV
06-28-2014, 12:04 PM #6Member
- Sep 2012
- Tucson, Az
- 55
I live in Arizona and 2 years ago when I bought my boat I had this problem maybe 4 times, once at lake Powell. I got tired of dealing with this (I'm an engineer) so I was looking at the fuel pump to figure out how to resolve the issue when I found an oil line resting up against the fuel pump. So, for a quick fix I took a zip tie and pulled the oil line away from the pump........and the issue went away. Now he pump is cool to the touch even at 110F outside. So, I would recommend looking at how your oil lines are routed and then go to the cooling of the fuel pump as a plan B. I'm a firm believer of KISS (keep it simple stupid). Good luck
2007 Moomba LSV
06-28-2014, 12:24 PM #7
06-28-2014, 03:47 PM #8
I don't think I have any oil lines next to my pump on the outback..I think mine just sits right next to the block. I'll have to look again..but if I remember it's just a mount right on the block and no oil lines near it
Exile XM7's
Exile Harpoon
Exile ZLD
Polk 10in sub (2)
