Results 1 to 9 of 9
    Jan 2006
    Jacksonville, FL
    Default Irritrol 700 sprinkler valve
    Does it matter which wore I hook to + and -? The wires are not labeled and it seems like hooking them up either way pulls the plunger in. Also where does the adjustment tab under the solenoid need to be to have it work on the switches? In the on or off position ? Thanks
    Oct 2009
    Lockport, IL/Cloverdale, MI
    I just replaced all three of our sprinkler valves with the Irritrol. Either way with the wiring is fine. The valve should be in the full off position,thus needing power to open.
    The water flow direction does matter though so make sure arrow on valve is facing right direction. It's a little hard to see but there is an arrow embossed on the valve.
    Regards,
    Bob
    2008 Outback V
    Nov 2013
    Kansas City, MO
    Exactly what he said ^ that silly on/off valve gave me fits. Has to be off.
    2007 LSV
    Sep 2005
    Claytor Lake, VA
    What they said. Polarity doesn't matter on the wiring. The on/off is just a manual override so on/off kinda makes sense. Valve works fine without it and I didn't see any reason to ever have then on all the time so I removed mine.
    2005 Mobius LSV
    Jan 2006
    Jacksonville, FL
    So just take off the solenoid and turn the black piece counter clockwise so that it is at the stop point ?
    Nov 2013
    Kansas City, MO
    No need to remove the solenoid. Just turn the black knob to the off side. Keeping it off is what keeps unselected bags from filling when the Rule is powered. If they are "off" they can only open under power by selecting the appropriate switch. Kind of reverse logic.
    2007 LSV
    Sep 2013
    Bennett, N.C.
    Is that the700B model? thanks
    2004 Mobius LSV 340 HP
    Gravity III Ballast
    750s in Rear
    Stock 400 in Front
    Jan 2006
    Jacksonville, FL
    I think so.
    Jan 2006
    Jacksonville, FL
    Works now. Thanks
