Results 11 to 20 of 28
  1. #11
    Aug 2010
    Nokomis, Saskatchewan
    Default Re: Mondo with the flow... first impressions
    Quote Originally Posted by Buckshot View Post
    Attachment 20235 this is from my mondo with 3 adults and 2 small kids. Stock ballast. Now I need to figure out how to stay in the sweet spot. Also are you guys finding any damage, boat or board, by taking off from the platform?
    That is a real nice wave!! Are you running stock bags in the back??
    2014 Mondo with da flow!!! Exile towers, stock everything else.... for now!
  2. #12
    May 2014
    Yep all stock so far
    2014 mondo
    Old- 2010 Campion chase
  3. #13
    Why would you want the platform off?
    Feb 2014
    He doesn't want the platform off, he wants to start off of the platform.
  5. #15
    Default Mondo with the flow... first impressions
    Why would you want to start off the platform?
  6. #16
    Feb 2014
    Drew,
    So you don't get wet!
    Or it looks/is "cool"
    With the boards that you and your family use, it would just crush the boards. With a compression molded board it is possible to start from the platform and not have the board be crushed.
  7. #17
    May 2014
    I bought a phase 5 trident.....is that compression moulded? I think it's carbon fibre,or at least looks like it.
    2014 mondo
  8. #18
    Feb 2014
    It is a carbon fiber board, however I would not personally start off the platform with that board...mainly because of how expensive it is. Most phase five boards won't get damaged from starting from the platform. It can be a little sketchy to start from the platform, and you always run the risk of shoving the board into the transom of the boat. When you kick the board into the transom you can crack the noise of the board, and scratch your gel coat....sad day
  9. #19
    May 2014
    Thanks that's what I was worried about.
    2014 mondo
  10. #20
    Aug 2010
    So we were out yesterday and I found that with 2 people in the boat (approx 325lbs total) I needed to dump out about 100-200 lbs to get the goofy wave to clean up.. regular is fine with both sides full. When we added one more person the goofy wave cleaned up with everything full
    Sent from my SGH-I337M using Tapatalk
