Results 1 to 10 of 14
    Aug 2007
    Alpine, Utah
    Default Need Screwing Advice
    I figured that title would get your attention. Here's my problem, some of the screws on my boat trailer that hold the wooden planks down (the planks that the boat sits on) are getting stripped. Last night I crawled under my boat to tighten them after seeing some of them half undone. Many of them I can't really tighten up because they are getting stripped. Does anyone have any suggestions besides replacing the would? Any tricks to get them tight?
    Thanks,
    Garn
    Garn
    2007 Mobius LS (Direct Drive)
    Take the bolt completely out, stick a few toothpicks in the hole around the perimeter (as many as needed). Snap off the ends sticking out. Reinsert bolt and tighten down. If too loose, add more tooth picks and repeat. The "new wood" will crush down and compress into the old wood. Not a permanent solution but will get you by for a while.
    Use bigger bolts-- assuming you can get them through the holes.
    Aug 2011
    Newnan, GA
    We use a wooden dowel for this type of temp fix
    2015 Supra SE 550
    De Pere WI
    I was going to suggest a little blue pill but don't want to see him come down with priapism
    Had to google that. Now kind of wishing I didn't...
    Thanks Scott!
    De Pere WI
    hope you google website and not google images
    Aug 2011
    Default Re: Need Screwing Advice
    Remove the boat, unscrew all the screws holding the bunk and move the bunk back or forward 1/2 inch and re screw....
    I drill a small pilot hole to make it easier..
    2002 Moomba Mobius LSV - Sold
    2006 Moomba Mobius LSV
    Mar 2003
    s.e. washington state
    Quote Originally Posted by parrothd View Post
    X2 except test the board first to see if the board is sound to start with.
    1998 Mobius
    310 HP PCM
    Jan 2014
    Texas
    Try some woodmate 2498. Works great on wood and fiberglass.
