Results 1 to 9 of 9
    Jul 2013
    North Mississippi
    Default Dive Mask saves the day!!
    Hello all,
    This being my first year with my LSV, I've spent countless hours on this forum researching and learning. One nugget of information I picked up which has been mentioned in a few threads was to include a dive mask in the "items to have on your boat" kit. I've seen a lot of pics of the lakes some of you guys are on, which you can almost see to the bottom. I mostly boat on Corp of Engineers lakes which are filled by run off and rain water. Basically a 500 acre mud puddle, with visibility of about 12 inches. At first I figured a dive mask would do me little good, but I got one anyway based on forum recommendations and figuring 12 inches of visibility is better than none. Good thing I did!
    Yesterday, I was on the lake with the family and 'it' happened. A break down in communication allowed the ski rope under the boat. Fortunately, I was only in idle speed forward and I happened to glance at the rope and saw it begin to go taught from the water to the tower. I immediately shut down the engine and assessed the situation. A tug on the rope confirmed my fear, prop got it. After a brief moment of "serenity now", I gathered my composure, and went right to my onboard "boat kit". I pulled out my brand new dive mask, labels still attached, and went in for a look. I just felt my way to the rudder, got within 12-18 inches and could see just fine. Sure enough, the rope was wrapped around the prop shaft about 8 to 10 times. After a few times coming up for air, I was able to unwrap and free the rope. I inspected the rope for damage, there wasn't any, and we were good to go! Thanks to some excellent advice from fellow Moomba Maniacs, we enjoyed the rest of the day.
    So, those of you that have a dive mask, excellent. Those of you that don't have one, get one...now. Don't put it on your 'to do' list. Do it, now. Walmart has them for cheap. Also, get a good knife in case you're unable to unwind the rope as I was.
    Thanks again !
    Steve
    2008 Mobius LSV
    1100#er's in the lockers
    ski locker sac
    IBS
    Johnson reversibles
    Jun 2014
    Dallas
    Hoorah! I learned that the hard way. On a very cold day the rope disappeared and it was difficult to deal with cold and blind. I now also keep swimming goggles on board. As well as...
    Gorilla tape
    Large leatherman
    Spare impellet
    Basic tool kit (pliers, screwdrivers, crescent wrenches, ring clamps, zip ties, etc)
    Whistle
    What else?
    Sent from my SCH-I535 using Tapatalk
    2005 Supra 24 SSV
    Lake Lewisville, Lake Leon
    Texas
    Nov 2013
    Kansas City, MO
    Dive mask. Genius. Thats going in tonight.
    My cooler turned into my tool box. Wire strippers, hose clamps, wire cutters, electrical tape, fuses, wire crimps, sockets, screwdrivers, channel locks, needle and regular pliers, crescent wrench, 3-4' of electrical wire, and the same of speaker wire.
    Then I have spare parts for the ballast bags, like hose and quick connect fittings.
    Carry a 12volt 5 gagillion candlepower spotlight, tons of rope, air horn, whistle, med kit, and paper towels.
    Adding an impeller as soon as it gets here. Anybody else got any more "necessities"?
    2007 LSV
    May 2013
    Vancouver WA
    I carry a dive mask and a snorkel. I also have a floating knife. I have a harbor freight tool kit as well with a little of everything.
    I probably should have jumper cables but I do have a 2nd battery on a switch.
    I think I should also throw a couple hose clamps in...
    Fuses, yes fuses are another good one. And if you have throw-over ballast pumps, have TWO because I had a friend send one to the bottom of the river...
    Oct 2008
    Central, Arkansas
    I have a pair of swim goggles and knife in my tool box... Luckily have not had to use it yet for a rope.
    Eugene OR
    a dive mask is a must. I have used it a few times on friends boats and a ooo moment when I hat a log and wanted to see if I damaged the prop or anything under the boat. I would not get jumper cables but have a jump box in the boat. It is a pain in the *** to jump another boat on the water. a jump box you can just pass it over and do not have to deal with a cable that is not long enough to reach between the boats. But my jump box sits in the truck most of the time after a month into boating season.
    Aug 2011
    You're missed two very important items....Zip ties and duck tape..
    2002 Moomba Mobius LSV - Sold
    2006 Moomba Mobius LSV
    Small waterproof flashlight with a wrist strap is handy if you ever go out at night. I've been under the boat untangling a ski rope we unfortunately found adrift in the middle of the river one night. Not a pleasant experience.
    Quote Originally Posted by Beejwest View Post
    what? where do the beverages now go? get a plastic, waterproof ammo box from Bass Pro or Academy and put that cooler back to better use.
    Drew
    2016 Supra SA 450
    2015 Supra SG 450
    2012 Moomba Mojo
    2008 Moomba OBV
