Results 11 to 20 of 21
    Default Re: Researching "quick winterization" options
    3/4 garden hose connectors, I just unsrcew and the water drains.
    If lucky you're can get your significant other blow the rest out...hehehe..
    2006 Moomba Mobius LSV
    Mar 2003
    s.e. washington state
    Disconnects? How cool is that?
    I have something like this, mine are plastic..
    https://www.google.com/search?q=petc...20618012423231
    Eugene OR
    I installed a ball valve in place of my block plugs. I got locking ones so they would lock closed. It was just two parts per side. A M to M thread that is the same size as the block plug and a ball valve. Took about 5 min to install and is a quick way to drain the block. For the hoses I just left them how they are since to disconnect the hoses is quick. It takes me about 5 min to drain all the water out if I am not messing with the impeller. I can take some photos this weekend if you want.
    Eugene OR
    This is one ones i used but locking.
    http://www.homedepot.com/p/Mueller-G...31NL/202283796
    Dec 2012
    Trois-Rivieres, Quebec
    I'm interested in photos...I got a brand new Mondo and would love to do those mod for my first winterizing...
    Sampp
    2014 Mondo
    Could be worst
    From nice Québec..
    Eugene OR
    Sounds good. I will be working on the boat this weekend and will get photos.
    Jul 2011
    Murrieta, CA
    Default Researching "quick winterization" options
    I am assuming that you do not have knock sensors in the drain locations. Am I correct?
    2010 Moomba XLV
    340hp cat
    Gravity 3, wake plate
    Rad-a-cage
    1100 v-drive lockers
    1180 under the playpen
    Eugene OR
    Yes you are correct I do not have a knock sensor on the block drain plugs.
    Eugene OR
    The images are from the port side of the engine. Starboard side looks the same.
