    Oct 2013
    Ft. Collins, CO
    Default Fuel line damaged by floor boards
    This weekend I installed a set of the Johnson ballast pumps. In the process, I pulled the floor up to install some 1" tubing. I started hearing a weird noise, like a large insect flying around me. Once I decided it wasn't a giant killer bee trying to eat me, I pinpointed the noise to the fuel line between the tank and the filter. There was a pin-hole leak in it, it was "gurgling" just a little as air was being drawn into the hose to equalize the pressure of the changing temperature (evening).
    It was then quite obvious: the hose was rubbing against the bottom edge of the floor panel and had worn a fatigue point. There are several design/install issues that I could see. The mounting of the filter and hose clamps pointed the hoses upward, putting pressure against the floor; if they had been aligned differently, the hoses probably would have laid flat against the tank. Secondly, the carpet was wrapped around the edge of the panel and offered some protection, but the carpet on mine has started to wear away leaving the sharp edge exposed.
    For now, my quick fix was to replace the hose (it was 1/2" but the parts stores around here only had 7/16" which fit fine) and I slipped a scrap chunk of the 1" water tubing over it for protection.
    I'd recommend a quick check on your boats. You can inspect this from the V-drive access without removing the floor panel. I felt like my boat had a stronger than normal gasoline smell after sitting for a while (about like a normal carbureted engine). I think this has diminished but it could be placebo effect. In any case, leaking fuel/vapor is pretty serious and it will only take a moment to check.
    1989 Sanger Skier DX - sold
    Mar 2014
    Park City, Utah
    Thanks for the heads up, strange thing is the fuel lines on my 06 go a different way then yours. I'll get a picture this weekend, but they go out of the tank straight to the stern then turn left to the filter.
    2013 Supra SA450
    2006 Mobius LSV - Sold
    2004 Stingray 190LS - Sold
    www.tffor.org
    Good post Greg - any member out there who has a spare 5 minutes should do a quick check. Maybe yours was just a fluke, but anyone else should find out for yourself!
    Salt Lake City, Utah
    that is a good find, I will have to check mine. Every now and then I get a stronger than normal smell of gas when I go in the garage. How do you get the floor up. I don't recall seeing any screws holding it in? Do you just remove the v drive cover and pull?
    Scott
    Oct 2013
    Ft. Collins, CO
    No, there are screws that you have to find. They are there, just hidden in the carpet. The rear section is easier because the screws are in the corners. I used an awl and tapped in the carpet until I heard the metallic clink when I hit a screw. (On the forward section, the screw by the drivers seat was not in the corner but along the edge pretty much half way along the length - I think some have only had 3 in this panel.)
    But... you should be able to check this without pulling up the floor. Just lift the V-drive cover and look at the fuel lines just as they come out from under the floor. I think there would be enough wiggle room to see if your lines are getting rubbed against the edge of the floor.
    Great, decided to pull up the floor to get a good look at the lines as well as see what was under there. Everything looked good with the lines and cleaned some nasty smelling gunk out while I was there. Thanks
    Scott
    Oct 2013
    Ft. Collins, CO
    Update: After fixing this, I have never noticed the gas smell after the boat sits under a cover. In fact, I had completely forgotten about it. So I definitely had a serious problem but it was easily remedied. I feel lucky that I had the floor up and was working in that area that evening when there was a good change in the air temperature. I don't think I would have ever found this otherwise.
    It's a good reminder to always run your blower before starting the engine. Fumes can come from the strangest places.
    Mar 2003
    s.e. washington state
    I would recommend replacing those wire nuts with butt connectors.
    Oct 2013
    Ft. Collins, CO
    Ha! That's not what you're supposed to be looking at in those pictures! That was just some temporary wiring to make sure I had everything connected correctly (ballast switches and pumps). All wirenuts have been long since replaced.
