Results 1 to 8 of 8
    May 2014
    Hoover, Al
    Default Swim platform pin fell out
    Discovered Sunday after trail wring the boat that I lost the port side pin that holds the swim platform on. Anyone else experience this?
    2012 Mojo
    2012 Mojo
    Des Moines, IA
    Both of mine disappeared last trip too. I replaced them with stainless bolts.
    I lost one last year while on the water. I also replaced with bolts at that time
    Jul 2013
    Cedar Falls, IA
    Yes, replace the pins with stainless steel bolts and nylon lock nuts. If you've not done so already, you can also replace those set screws with SS bolts.
    2013 Moomba Mojo 2.5
    Exile SXT9's, Xi12D, Javelin, 800.4, ZLD MKII
    SUMO 900's in rear, 650 IBS and FLOW
    2012 Ford F150 Ecoboost
    May 2014
    Hoover, Al
    Thanks guys! Will do all Thursday.
    2012 Mojo
    May 2014
    Hoover, Al
    Uni,
    Remember what size you used?
    2012 Mojo
    Jul 2013
    Cedar Falls, IA
    1/4" - 20 will fit in the set screw holes. I used a jam nut to retain the torque. I actually opted to open up the 2 two spring holes to 5/16" since they were no longer tight at 1/4".
    So far it's held up to a 3 day weekend full of surfing.
    May 2014
    Hoover, Al
    Got it all wrapped up on Thursday. Will be at Lake Martin all from fri-Monday testing it out!
    Thanks guys!
    2012 Mojo
