Results 1 to 10 of 13
    Nov 2013
    Kansas City, MO
    Default Boatmate trailer hub question.
    Anyone know off the top of their head what weight oil/lube the hubs on my '07 boatmate trailer uses? It looks like it's a wet type bearing, not a greasable hub like I'm used to. There is what I belive to be a fill port, with a nipple to add lube. If no one knows I'll just call boatmate I suppose. Thanks!
    2007 LSV
    Nov 2008
    '13 Mobius LSV
    '05 Mobius LSV - Sold
    Mar 2012
    South Carolina
    I just regreased all of my hubs (had a leak in one seal and had to replace) just a few weeks ago but my trailer is an '08 and I don't have any nipple. I just went to advanced auto and got auto bearing lube, forget what though. Boatmateparts.com sells the lube but they are a ripoff in my opinion.
    Nov 2013
    Kansas City, MO
    Thanks CSM!
    2007 LSV
    Jul 2013
    North Mississippi
    Do you guys have "The Vault" hybrid lubrication system on your hubs? It's supposed to be maintenance free?
    2008 Mobius LSV
    1100#er's in the lockers
    ski locker sac
    IBS
    Johnson reversibles
    May 2014
    Clermont, Fl
    "The Vault" is not maintenance free.
    Every once in a while check the back of your trailer wheel hubs for leaks - I had a seal blow out and it is rather a PITA to repair.
    Even removing the cap requires a replacement from the manufacturer - and a tube of grease, a new rear seal, an O-ring and some permatex seal adhesive.
    Aug 2011
    Newnan, GA
    I have the vault system, it says maintenance free but the manual says to service them every 5 years. I checked the hubs every time I stop for ice/gas for excessive heat or leaks. I plan on servicing them at the 5 year mark if I don't have a no problems before then.
    2015 Supra SE 550
    Quote Originally Posted by slipperyrockTKE300 View Post
    I replaced all 4 of mine. It is no different than repacking normal hub bearings IMO. You can get all the parts that boat mate sells at www.pacifictrailers.com for a fraction of the price.
    Jan 2013
    Northeast, PA
    I've replaced mine last year and I bought everything from www.pacifictrailers.com as well. I used the Vault bearing grease as it is designed to lubricate the UFP hubs, I don’t want to burn up the bearings down the road, even more costly. Only problem I had was once I pulled the bearing protector my one hub did not have the 1/8” hole for grease fitting to fill space between the inner and outer bearings correctly. I had to remove the cotter pin pull and remove the large nut off the spindle and pop out the outer bearing and fill the void between the bearings, very easy but very messy. Then just put the outer bearing back in and replace the large nut and cotter pin. Then follow the directions to install the new bearing protector. Very easy, just messy!
    2007 Moomba Outback V
    Mar 2012
    South Carolina
    Seconded on PT, David sent me their info when I replaced mine. And I do have the Vault, I guess the OP was referring to something different. I didn't think it was that much of a pain to change the seal or repack the grease, just messy as hell and a little time consuming.
